Heating up 97 7.3l - Ford Powerstroke Diesel Forum
post #1 of 5 Old 09-13-2013, 02:17 PM Thread Starter
Heating up 97 7.3l
I just bought this new truck 97 powerstroke with 144,000 miles on it. It needed a new solenoid pack in the tranny's so we replaced that and that fixed a lot of its problems. But the engine is heating up more than my old truck ever did when I was towing of 15,000 pound trailer. It goes all the way up to M in "normal" Just by driving it for five minutes. The radiator doesn't have a cap directly on it, but has an additional overflow box that you put the water in. So I can't tell if the water is circulating or not. Is my right radiator bad? Is there anyway I can test it?
janelldawn92 is offline
post #2 of 5 Old 09-13-2013, 02:30 PM
Try a new thermostat. It may have one in it that's meant to get warmer (northern truck).
injun46 is offline
post #3 of 5 Old 09-13-2013, 02:38 PM Thread Starter
So you think the thermostat went bad in it or?.. Is it easy to get to?
post #4 of 5 Old 09-13-2013, 03:15 PM
cheysays7.3's Avatar
Does it go any higher than "M"? That's higher than mine, but you could have a hotter thermostat. Mine gets to the "O" and stays. Even hauling 4 horses in a stock trailer (not a light trailer either). I have the 205*. Most people use the 203* stat.
1995 F250 7.3 ECLB - 6637, 3" MBRP downpipe, Autometer Pro Comp Ultra lite Boost pyro and trans gauges, Heavy Duty built trans, Proline FlatBed, and much more to come!
cheysays7.3 is offline
post #5 of 5 Old 09-13-2013, 03:53 PM Thread Starter
How would I tell if its a high temp thermostat? It was at M and then after running a little bit went to O.
