Help: EBPS tube problems - Ford Powerstroke Diesel Forum
post #1 of 3 Old 09-13-2013, 09:41 AM Thread Starter
Today I decided I was going to clean out my EBPS tube and sensor. Ever since I've had the truck, it seemed like it was somewhat lagging during acceleration. I pulled the sensor off and there was a little soot inside. I then went to pull the tube, and that's where the problems started. The top side was fine, but I noticed there was some white wrapping on the bottom of the tube. On further inspection, it ended up that the tube actually wasn't even connected to the exhaust manifold.
If it was just a broken tube, there would be no issues as I could just replace it. Unfortunately with it broken completely off from the motor, I have no idea how I am going to fix it. What are my options? Help please .
DChalue413 is offline
post #2 of 3 Old 09-15-2013, 08:16 AM
leojr's Avatar
Quoted: 4 Post(s)
I want to remove and clean mine and will watch this thread in case I need to solve a similar issue. Good luck!
Denton, TX
I envy those that know exactly which modification to make and in the most logical of sequences. But not enough to trade for my meanderings and misfires.
1996 F250 crew cab/short bed, 4x4, auto PSD, 6637 air filter, interior grab handles, stainless window vents, remote door locks work with engine running mod.
leojr is offline
post #3 of 3 Old 09-15-2013, 10:42 AM
Quoted: 50 Post(s)
Very judicious use of an easy-out should get that threaded portion of the fitting out of the manifold, since it's already hollow. Hit it with PB-Blaster or Kroil. Tap the extractor into the fitting until you see it start to turn counterclockwise. Then start turning it with a wrench or vise-grip.
madpogue is offline
