help, no start no oil pressure - Ford Powerstroke Diesel Forum
post #1 of 4 Old 09-12-2013, 06:53 PM Thread Starter
timmy's Avatar
My 96 up and died on me on my way to work , narrowed issue down to lpop. Changed out pump and now I still have no oil pressure. The truck will start and run temporarily when hpop reservoir is filled. We pulled oil filter and cranked motor over, no oil at filter housing. Any help would be greatly appreciated, I'm at a loss for ideas.
96' f-350 2wd,5spd, C+C w utility body, 370,000miles
timmy is offline
post #2 of 4 Old 09-13-2013, 12:27 PM
Patrick Feeley's Avatar
Quoted: 15 Post(s)
Cracked oil pickup tube? There's a procedure for overfilling the crankcase and jacking up the rear end of the truck to check. I'll look and see if I can find it. Cheers!
Patrick Feeley is offline
post #3 of 4 Old 09-13-2013, 05:20 PM Thread Starter
timmy's Avatar
The pickup tube is all I can come up with, pulling the motor tomorrow to find out.
timmy is offline
post #4 of 4 Old 09-13-2013, 06:51 PM
Quoted: 15 Post(s)
Isn't there an o-ring for the pickup tube to front cover joint? You might check to see if it is missing or damaged. Cheers!
