I Lost a Ball... - Ford Powerstroke Diesel Forum
post #1 of 21 Old 09-09-2013, 08:32 PM Thread Starter
Exclamation I Lost a Ball...
I'm in the process of replacing my oil pan, and while I walked past the engine stand I found this....
I'm praying that it is a check ball out of the oil filter housing, and not out of a bearing. I don't have a very good knowledge of the inside of these engines.
Where could this of come from?
I really dont want to have to rebuild the engine. Moneys tight and this is my only transportation.
Thanks!
-William
Heres a crappy picture of the underside of the filter housing.
williameub is offline
post #2 of 21 Old 09-09-2013, 08:49 PM
White Noise
AU7POINT3's Avatar
Quoted: 2 Post(s)
If that fits inside that small hole shown in that pic of the oil filter mounting location, I'd be surprised. What would hold it in?... I think it's more likely a ball bearing out of your engine stand or jack caster wheel...
2002 F-250 LARIAT CCSB 7.3 AUTO 4X4 261,XXX
2004 EXPLORER XLT 4.0 AUTO 2WD 130,XXX
1966 MUSTANG COUPE 289 4 brl V8
IN-LAWS...
2004 EXPLORER SPORT TRAC 4.0 4X2 100,XXX
2004 F-250 RCLB 6.0 AUTO 4X2 38X,XXX
2005 F-250 RCLB 6.0 AUTO 4x2 36X,XXX
SOLD... 3 RANGERS, 3 F-150s, 3 F-250s, 96 COUGAR 4.6, 99 EXPEDITION 5.4, 65 66 AND 69 MUSTANGS
RE-ASSIGNED... MULTIPLE FORD POLICE INTERCEPTORS
AU7POINT3 is offline
post #3 of 21 Old 09-09-2013, 08:57 PM
ZMANN's Avatar
Quoted: 1334 Post(s)
my wheels on my jack spit bearings like that
good call
We Miss you Ronnie
ZMANN is offline
post #4 of 21 Old 09-09-2013, 09:03 PM Thread Starter
It couldn't be out of the caster wheels. I have concrete blocks under the engine and it was resting on those blocks.
post #5 of 21 Old 09-09-2013, 09:05 PM
ZMANN's Avatar
so your engine stand has no wheels?
and you didn't use a floor jack ?
other than check balls I can't think of a ball bearing that could sneak out of the motor ?
We Miss you Ronnie
ZMANN is offline
post #6 of 21 Old 09-09-2013, 09:07 PM
White Noise
AU7POINT3's Avatar
Quoted: 2 Post(s)
Been through a lot of engines, never seen a roller bearing inside of the typical type, just cam/ crank aluminum type bearings and needle bearings that look like little rods. If there was fresh oil from your engine all over it and a spot where it stuck to your shop floor I would raise an eyebrow. Probly from a caster. Paint your oil pan really good before you put it back on...
IN-LAWS...
post #7 of 21 Old 09-09-2013, 09:10 PM
White Noise
AU7POINT3's Avatar
Quoted: 2 Post(s)
Does an oil filter with an anti-drain-back valve have a check ball and spring in it? Usually silicone.Take apart an old filter and see...
IN-LAWS...
post #8 of 21 Old 09-09-2013, 09:35 PM Thread Starter
Heres the weird thing.
It was found on a concrete block directly under the engine, above the casters. I keep my casters greased and there was no grease on the ball. But there wasnt any oil on it either.
It was pretty clean.
No one has been around the engine but me and I know I didnt put that thing there.
The only thing I can think of is that I had a throwout bearing go bad on me about a month and a half ago. Sent little balls everywhere. But, I've driven the truck since then, replaced the tranny and pulled the engine since that t/o bearing went bad. And now after all that, while the engine was sitting still over night, that little bastard decides to roll out of his hiding spot and plant himself directly under the block? Its kinda hard for me to wrap my head around. I have an extra t/o bearing thats thrashed. Im going to tear it apart tomorrow and compare the sizes of the balls.
post #9 of 21 Old 09-09-2013, 09:50 PM
White Noise
AU7POINT3's Avatar
Quoted: 2 Post(s)
That's a thought. Could've been stuck to something greasy or hung in a crevice until you took the other stuff apart. I don't think it's internal, either way. Other crap would've been hung in your oil pump screen most likely.
IN-LAWS...
post #10 of 21 Old 09-09-2013, 09:57 PM Thread Starter
Yeah, and there wasnt any metal shavings on the drain plug or in the pan...
My plan was to have the pan back on tonight, but after I found that ball I stopped what I was doing.
You think it'd be alright to install that pan tomorrow?
