Cps - Ford Powerstroke Diesel Forum
post #1 of 7 Old 09-07-2013, 11:51 PM Thread Starter
97Strokin''s Avatar
Cps
My truck has developed rough idle and lopes about every 6th start or so (depending on the day) truck throws cps code p0344. I figure it needs a cps but want a second opinion. is there a way to test the cps without throwing parts at it?
1997
F250
3" DP"
4" exhaust
5" Tip
TS 6 Position
17" AR Rims
4" lift
97Strokin' is offline
post #2 of 7 Old 09-08-2013, 06:34 AM
Patrick Feeley's Avatar
Quoted: 15 Post(s)
Most guys simply replace the sensor since they are cheap and if it doesn't solve the problem you have a spare for the glovebox. You would need to tap the signal and probably have access to an oscilloscope to test it. Make sure you take a look at the sensor connector and wiring too. Cheers!
Patrick Feeley is offline
post #3 of 7 Old 09-08-2013, 11:54 AM
Arcturus's Avatar
I just had the same code and it was probably just grease in the connector. I changed it out anyway and now have a spare. Big Fuel had exposed and nasty wiring at the connector and soldered on a new connector. The sensor is around $35. I got the IH CPS.
JackT
1996 ECLB 4x4 81k miles
DIY 6637, Hpx, E4OD
First boat Arcturus
2008 Kubota L-39
Arcturus is offline
post #4 of 7 Old 09-08-2013, 05:14 PM Thread Starter
97Strokin''s Avatar
Where is the cps at in t these trucks?
1997
F250
3" DP"
4" exhaust
5" Tip
TS 6 Position
17" AR Rims
4" lift
post #5 of 7 Old 09-08-2013, 05:32 PM
aussie=effie
bob harris's Avatar
Smile CPS
DOWN FRONT BOTTOM OF CRANKSHAFT, EASY TO CHANGE. IH ARE SUPPOSED TO BE BETTER ?
bob harris is offline
post #6 of 7 Old 09-08-2013, 05:51 PM Thread Starter
97Strokin''s Avatar
How are the ones from riffraff?
1997
F250
3" DP"
4" exhaust
5" Tip
TS 6 Position
17" AR Rims
4" lift
post #7 of 7 Old 09-09-2013, 10:41 PM
I'd just get the ford cps, at least you know the quality is OK, unlike the others.
96 F-250 XLT 7.3l Crew Cab 4X2 5-spd
jfwatson is offline
