96 psd jerks when going down the road - Ford Powerstroke Diesel Forum
post #1 of 3 Old 09-07-2013, 05:41 PM Thread Starter
Going down the road the check engine light came on and i have no throttle. The CEL will go off and then i have throttle again. I changed the TPS and that did not help. I changed the IVS and that did not help. Am not at the house so I cant plug into it. Any advice would be appreciated.
94.5 F350 CC LB 4X4 5 spd
AFE Stage 2
4" Exhaust
Turbo Upgrade
TS 6 Pos Chip
FPR Shim
Equailzer hose
3 gauge a pillar pod, Pyro, Boost, and soon to come Fuel Pressure
kevinwoo11 is offline
post #2 of 3 Old 09-07-2013, 05:50 PM
WNY Biodiesel Co-op
greasyF250's Avatar
Quoted: 6 Post(s)
your loosing the 5v reference voltage at one of the sensors, ebps, coolant temp, oil temp and pressure sensor . your grounding out somewhere on this 5v circuit.
2000 F250 King Ranch Crew Cab 7.3L LB 4X4 100% home brewed Biodiesel
ZF6 6SPD trans
Zoo Dad Mod
DP F5 Tuner
Wicked Wheel
AFE Intake
4" straight exhaust with 5" tip
Isspro 3 Gauge Pod
285/75/16 Cooper ATP on factory 16's
Banks Big Head
298K
greasyF250 is offline
post #3 of 3 Old 09-07-2013, 06:15 PM Thread Starter
10-4. I guess at light I will start checking and tracing wires. Let the fun begin.
AFE Stage 2
4" Exhaust
Turbo Upgrade
TS 6 Pos Chip
FPR Shim
Equailzer hose
