ICP Sensor Lfe Expectancy - Ford Powerstroke Diesel Forum
post #1 of 2 Old 09-06-2013, 06:42 PM Thread Starter
Hello All,
So my 97 ford is experiencing issues with starting hard. I had similar issues about a little over a year ago and was directed to check the ICP sensor. After checking the connection sure enough there was oil inside the plug. I replaced sensor with a genuine ford part and a year later I started experiencing hard starts again. I just checked the year old ICP sensor and found oil in the plug again. Is this normal for an ICP sensor to go bad so soon or could there be some other cause of my issues?
Thanks.
Dorfy is offline
post #2 of 2 Old 09-07-2013, 12:32 PM Thread Starter
Ok so I replaced my ICP sensor and that didn't fix my issues. Any other suggestions? I've looked around the HPOP for oil leaks and found none.
Dorfy is offline
