97 OBS no start - Ford Powerstroke Diesel Forum
post #1 of 10 Old 08-30-2013, 11:13 AM Thread Starter
97 OBS no start
I bought the truck to fix. Owner had it diagnosed as hpop bad. I replaced that and cannot get it to start. Tried different IDM and CPS. still nothing. disconnected GPR and used a small squirt of either....fires right off then dies. Wait to start light works, gauge shows oil pressure when cranking. motor does crank over fast enough to start. Only thing I can see is the fuel bowl never seems full when I check it. I was gonna change the filter and go from there. I think it may be fuel related. Any ideas for me? Thanks, Ken
barrakudaman is offline
post #2 of 10 Old 08-30-2013, 11:21 AM
Mob boss
Jarrod B's Avatar
Quoted: 149 Post(s)
could be a weak lift pump.
hpop res full too?
when my lift pump died, it took starting fluid to start up and ran on its own fuel after that. mech said the pump was too weak to start but enough to run.
btw if using ether, unhook the power to the glow plugs.
2006 Ford F250 CCSB FX4 6.0
Sold
1997 F350 CCLB 2WD 7.3
1999 F350 CCLB 4WD 7.3
2003 F350 CCLB FX4 6.0
LSP Chapter Director
LSP Group Threads
Jarrod B is offline
post #3 of 10 Old 08-30-2013, 03:00 PM Thread Starter
I will check hpop res. I did disconnect the GPR when trying small shots of ether. Maybe the lift pump on mine is completely shot. Whats the best way to figure out if the lift pump is bad?
post #4 of 10 Old 09-02-2013, 11:42 AM Thread Starter
So I swapped out the lift pump and fuel bowl from an old truck I had that was running. still no luck. I will be running a snap-on scanner on the truck tomorrow. Any more ideas for me? Can diesel fuel get rancid? Or go bad? because the stuff in this truck just doesn't smell right
post #5 of 10 Old 09-02-2013, 04:08 PM Thread Starter
hpop resivor stays full as well.
post #6 of 10 Old 09-03-2013, 11:47 AM Thread Starter
Well I went through the entire fuel system on the motor today. everything is working as it should. Fuel should be getting to the injectors without issue. Scanner said ipr circuit fault. P1283 was the code. I am wondering if the hpop I put on is bad or just the ipr valve. I would think if it was the injectors, the truck would still start. One thing I noticed is that someone has spliced into the factory harness by the valve cover gaskets. maybe the wiring would be the problem with the ipr circuit fault?
post #7 of 10 Old 09-03-2013, 11:57 AM
Mob boss
Jarrod B's Avatar
Quoted: 149 Post(s)
you should still start on half injectors if the driver side harness was cut.
but check your ipr wiring. shouldnt get any faults for that.
Sold
LSP Group Threads
Jarrod B is offline
post #8 of 10 Old 09-05-2013, 02:39 PM Thread Starter
I took the ipr valve out of the old hpop that was in the truck when I got it. There was quite a bit of slime on it where the solenoid rides. I wonder if just a good cleaning would do the trick. Can you rebuild the ipr? or is it best just to replace. I do have another hpop I could throw in the truck, but I am not 100% sure it is good either. I checked the fuel bowl harness when I installed the new bowl and it looked good.
post #9 of 10 Old 09-08-2013, 05:47 PM
Mob boss
Jarrod B's Avatar
Quoted: 149 Post(s)
i know you can just buy the ipr itself and not buy the solenoid. but idk on the rebuild.
yeah clean the contacts but I don't think that will solve it. I would just buy a new one from a sponsor, riffraft, or a new oem one off ebay.
Riffraff Diesel: IPR Injection Pressure Regulator 96-03
also for the fun of it, unplug the fuel bowl heater. I don't remember exactly, but when that shorts out, it causes another no start issue. just throwing that out there.
Sold
LSP Group Threads
Jarrod B is offline
post #10 of 10 Old 09-09-2013, 01:20 AM
Yes diesel can go stale so I would drain the tanks first off.
You can replace the IPR orings for 12.00 from dieselorings.com, but P1283 is a wiring fault code. Ohm out the IPR solenoid should be 5-20 ohms, check both harness leads to ground should be Kohm or higher, KOEO check volts to ground at the IPR, one lead should be 12v and one <.25v.
Joe
96 F-250 XLT 7.3l Crew Cab 4X2 5-spd
jfwatson is offline
