installed stage one injectors and 17* hpop - Ford Powerstroke Diesel Forum
post #1 of 6 Old 08-30-2013, 05:09 AM Thread Starter
Hey guys hows it going new here .. names shane I have a 1996 f350 7.3. Just had a buddy install stage one injectors and a 17* hpop. also had my ts chip re burned as well. The injectors were out for a couple of days as he removed them to give the cores back. when I delivered the truck to him drove 2 hours and truck ran great. He installed the injectors and hpop and went to fire the truck and all it does it crank. He cranked and cranked and never started.. he didn't remove glow plugs to get oil out of cylinders he said while injectors were out he turned motor over by hand and shot oil out of the cylinders.. he filled hpop resivor and all.. wait to start light comes on and works normal.. when cranking no smoke was coming out of exhaust either.. he was telling me it was the ipr but truck ran great when I brought it to him..
right now the tuner isn't even hooked up because he tried to start the truck without that plugged in to see if it would run. checked all fuses for fuel bow all in truck under dash under hood and all.
any ideas on what couple of happened?
cubid1997 is offline
post #2 of 6 Old 08-30-2013, 03:29 PM
Sam Burton's Avatar
it usually does take a bunch of cranking to restart after injector swaps, you need to purge the oil and fuel galleys before they will flow.
1978 Ford Bronco
12v Cummins
ZF-5 NP 205 10.25 rear Dana 60 front
Denny T fuel pin 366 governor spring
HX 35 turbo BD exhaust brake
Powerstroke intercooler
1990 F-350 Crew-Cab Short Box XLT 4x4
Powerstroke E4OD
170cc stage 1 injectors, superduty intercooler, flowmaster 3" down pipe, 4" exhaust, 6637 filter, 17* HPOP, Wildman tunes, build E4OD, 5 disc billet converter, Irate E-fuel, 1.0 exhaust housing, WW2, CCV mod, homemade RSK
Sam Burton is offline
post #3 of 6 Old 08-30-2013, 10:16 PM
Gaius's Avatar
Quoted: 50 Post(s)
Mine took much longer than I thought after doing injectors. Had to recharge the battery a couple times. Probably 5 or 6 20-30 second cranks. It won't light off until it sees high enough HPOP pressure.
05 F350 Crewcab
98 Jeep TJ - wheeler
Gaius is offline
post #4 of 6 Old 08-31-2013, 01:45 PM
schlutzer's Avatar
Quoted: 18 Post(s)
My buddy with a 95 just rebuilt his fuel bowl and it took us a long time to get the truck to fire ( we didnt know you had to refill the bowl manually I have a 99) I had to use my truck to boost while we cranked his over.
After about 3 minutes total ( 15 second cranks) we started seeing smoke. Then it started to try and cough. We had hooked up a fuel pressure gauge and that's how we knew we were on the right track as you could see if go up with every turn of the motor.
His neighbours must have hated us, but it started... took a few days to really run smooth again though.
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #5 of 6 Old 09-02-2013, 10:53 AM Thread Starter
yeah we cranked this truck for a while a lot longer than normal.. there is oil in hpop reservoir, I put 12v to the ipr and it clicked.. getting a idm fault code and a high low volt circuit bank 2.. cranked it more and still nothing.
post #6 of 6 Old 09-02-2013, 12:29 PM
Quoted: 896 Post(s)
Feedback Score: 3 reviews
Sounds like one uvch isn't plugged in all the way and its taking longer than normal to start. It won't start since one bank is not firing the injectors to let the air out of that side galleys.
Corey@CNCFAB is offline
