Vacuum pump or master cylinder? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 08-29-2013, 12:00 PM Thread Starter
OBS Strokin's Avatar
Hey guys my truck has lost brakes at times. My brake light will come on and stay on after I use them and when I speed up it goes off. When I first use them after awhile I have rakes but if I let off and push the, again she is hard as a rock and it acts like I using my brakes like the truck was off and had no power to them. Any suggestions and any ways to test vacuum pump so I don't just go buy a new one?
Thanks
96 7.3 F350, 4x4, 5 speed, 6 inch skyjacker lift, 35 12.50 M/T Baja Atz, custom TW 6 pos, Banks Intercooler, BDP experimental fuel system, banks double shot water meth, Chromoly Push Rods, Swamps IDM Mod, 2nd Gen Wicked Wheel, Stage II AFE cold air intake, Down Piped 5 inch Diamond Eye exhaust, Gauges, ladder bars, upgrades drives lines yokes, on board air system, triple trumpet train horns, smoked head light and taillight housings, and 55watt HID kit!!
OBS Strokin is offline
post #2 of 3 Old 08-29-2013, 06:05 PM
Patrick Feeley's Avatar
Quoted: 17 Post(s)
Check all hoses and manifold for possible leaks. Put a gauge on the vacuum manifold and you should see 17-24" Hg at idle. I would lean more to the pump being bad based on the description. Cheers!
Patrick Feeley is offline
post #3 of 3 Old 08-30-2013, 01:01 AM Thread Starter
Ok awesome! Thanks
