Cuts off when at idle/major oil leak - Ford Powerstroke Diesel Forum
post #1 of 5 Old 08-28-2013, 12:56 PM Thread Starter
Just picked up a '96 F350 standard cab 5sp 4x4 flat bed (love this truck) got it for a song to boot!! 246K and counting. Funny thing happens when you first start it up. It will idle fine for 5 minutes or so then either dies or starts the run-sputter-run-sputter then die drama. If I start it up again it usually runs fine the rest of the day. If I don't let it warm up (and let it go through its drama) and just start it and go, it will do the sputter-run-sputter-run thing while I'm driving. Sometimes it will die, sometimes I'm able to keep it going. Not sure what's going on here? Any ideas? Also sprung a very heavy oil leak on a recent trip from colorado to texas. LOTS of oil in the valley. Pretty much did an entire oil change on the trip there and back!! HPOP seals/o-rings? I do have one bad injector and will be replacing the glow plugs at the same time as I do the injector. Last owner (colorado rancher) was hard on it. Also noticed that this was a remanufactured engine from for in 99 I think.
TexasRanchStrokin is offline
post #2 of 5 Old 09-18-2013, 05:55 AM Thread Starter
OK! So I finally got around to doing a few things. I found ALL of my glow plugs to be bad, so I replaced all of them...Now my brand new GPR is bad or at least I think it is. Is it possible to wire it backwards? When I first installed it (with the bad plugs) It seemed to be operating correctly, i.e. 12V on the hot side 0V on the GP side until you turned on the ignition then 12 V on the GP side. Now with new plugs and ignition in the on position, I get 12V on hot side and 0V on GP side. Good thing I got the warranty on it. I'm going to exchange it today.
I replaced the passanger side injector closest to the firewall because it seemed dead when I tested it while running (no change in engine noise when I unplugged it). Pulled the HPOP and replaced ALL the O-Rings, new VCG's, new fuel filter assy and fuel filter, K&N cold air intake.
Got it all put back together late last night and it still seems to miss???
May I have a wiring issue, like a broken wire somewhere?
What kind of voltage or signal am I looking for from the wiring harnes to the injectors?
Also, is there supposed to be a gasket for the breather assy. on the drivers side valve cover? LOTS of smoke coming from there!
Any help would be greatly appreciated!
post #3 of 5 Old 09-18-2013, 05:59 AM Thread Starter
Oh, and I seem to have fixed my oil leak! That's good news. Ran the truck for 20 minutes and it didn't cut off or do it's drama thing either....hopefully I fixed that too!
post #4 of 5 Old 10-16-2013, 07:48 PM Thread Starter
Fixed the drama thing too! Simple CPS change did the trick! DO NOT GET THE CPS from NAPA!!! I got two and both were P.O.S!! Got the one from ford and it works correctly. Now on to the next project...Changing the steering wheel to add cruise control!!
post #5 of 5 Old 10-16-2013, 09:02 PM
Patrick Feeley's Avatar
Quoted: 13 Post(s)
Glad you seem to have figured it out. Don't know how I missed seeing your other posts. Cheers!
Patrick Feeley is offline
