Fuel pressure at Bleeder - Ford Powerstroke Diesel Forum
post #1 of 12 Old 08-24-2013, 03:42 PM Thread Starter
hey does anyone know what the fuel pressure should be at the bleeder on the water separator while cranking..the truck wont start.
RushFORD is offline
post #2 of 12 Old 08-24-2013, 09:22 PM
Patrick Feeley's Avatar
Quoted: 13 Post(s)
25 psi minimum at a minimum crank speed of 100 rpm. Are you getting the Wait-to-Start light? Tach showing any rpm while cranking? White smoke out the exhaust? Oil level good? CEL on? Cheers!
Patrick Feeley is offline
post #3 of 12 Old 08-25-2013, 01:46 PM Thread Starter
Alright the cranking was at 10 psi so I changed the fuel pump and cleaned the water separator screen. I have a wait to start light , the glow plugs are working because it dims after about 2 seconds of being on. tach is moving, either no white smoke or very lttle. And whats a "CEL"? Thanks for the response.
RushFORD is offline
post #4 of 12 Old 08-25-2013, 01:49 PM Thread Starter
New HPOP, CPS, IPR, Fuel pump, Computer, switched out a brand new IDM, no difference. It will crank for about 5-10 seconds fire like it gonna start then just crank again and repeat.
RushFORD is offline
post #5 of 12 Old 08-25-2013, 01:50 PM Thread Starter
NO CODE PRESENT
RushFORD is offline
post #6 of 12 Old 08-28-2013, 02:54 PM Thread Starter
Alright so cranking pressure is about 20psi at the shrader valve. I have a new HPOP,IPR ,ICP sensor,CPS,FPR mod done, clean fuel filter, fresh oil change. Tach moves while cranking,WTS light is good and when i swich tanks they both read different, my question is if im getting a reading from both tank levels does that eliminate tank selector/valve?
RushFORD is offline
post #7 of 12 Old 08-29-2013, 11:10 AM
john galt's Avatar
Quoted: 1213 Post(s)
the best i can do for you is give you a
I like mead
early 04 f350 6.0 cclb lariat sr
Bulletproof oil &egr, elc, sct x3, edge CTS, afe intake, blue spring, t-500, MTW stage 2, Vivians looney, 305 x55x20 bfg at ko's, 4 inch cat back, 4"BDS fox shocks and steering stabilizer, tri pilar gauge set, coolant filter, riff raff boots, new headliner, 7 inch touch screen w/back up, new carpet, near whole new interior,
FederalOwnershipRespectfullyDeclined
john galt is offline
post #8 of 12 Old 08-30-2013, 04:58 AM Thread Starter
Defect Cam sensor
so before all this work i just did, i put a cam sensor in the truck because it was running perfect then just quit. And thats normally the symptoms of a bad Cam sensor, the trucks got about 200,000 on it. so hear it is 2 months later and the truck still isnt running but after replacing all the parts i listed before , and trying to crank it over after every part replacement. The CEL finally threw a code, for the brand new CPS i put in. Im goin Defect it out with Advance Auto where i got it and put another one in. HAs ANYONE ever come across this same issue of having a defect Cam sensor?
RushFORD is offline
post #9 of 12 Old 08-30-2013, 06:13 AM
Quoted: 13 Post(s)
There have been plenty of folks that have gotten a bad CPS right out of the box (especially from the local auto parts houses). I get mine from Ford. Cheers!
post #10 of 12 Old 08-30-2013, 08:55 AM Thread Starter
well i put a new CPS in it, still no start, this thing is really starting to discourage me.Ive got about 30 hours of time and about $1000 bucks in it just for this one random no start situation. I need some help!! Thanks
RushFORD is offline
