96 HPOP leak... - Ford Powerstroke Diesel Forum
post #1 of 9 Old 08-21-2013, 06:01 AM Thread Starter
96 HPOP leak...
Ok so I just picked up my 7.3 and vally was full of oil. After cleaning it out I was able to determine that the oil is dripping off the bottom of the HPOP, Im not sure if it is the Non servicable plug or the Flange Gasket. Im leaning toward the flange gasket becasue i put a paper towel wraped around a piece of wire under the HPOP and it seems to be getting fresh wet oil under the HPOP but not under the plug. If the plug was leaking do they usually leak bad/fast?
I am going to be dissasembling the Truck today to get the HPOP off. I ordered an O ring kit ---> 7 3 Powerstroke Complete Hpop Repair KIT W Long Thread | eBay
And a new flange gasket ----> Ford 7 3L Powerstroke Hpop High Pressure OIL Pump Injector Pump Mounting Gasket | eBay
Is there anything I should know befor digging into this?
Is there a write up on how to do this the best / easiest way?
Im new to diesels but I am very mechanically inclined. Excuse my grammer, it is not one of my strong points...
Thanks for the help guys.
P.S. please help me so I can get this thing fixed for labor day weekend, I need to tow this --->
nooch450 is offline
post #2 of 9 Old 08-21-2013, 07:50 AM
Dieselorings.com has good instructions on how to do it. Not really that hard, just time consuming and aggravating.
Get a couple cans on brake or carb cleaner.
From my experience when the plug goes it goes with a lot of oil. Not just a little drip.
Sent from AutoGuide.com App
2001 F350 SRW CC 4WD LB
ZF6 w/ Southbend, 220k, DIY Intake, WW,NonEBPV Pedestal, CCV Mod, Gauges (Boost, Pyro), 2in Leveling Kit, 4" Straight MBRP, AIH Delete, 2-12" Kicker Comp's, Pioneer Amps
2001 F350 DRW EC 2WD (Rolled Over)
2000 F550 CC 2WD
Automatic, Jasper 4R100 w/Derale Pan & 6.0 Cooler, DIY Intake, AIH Delete, 4" MBRP,
Schnot is offline
post #3 of 9 Old 08-21-2013, 08:11 AM Thread Starter
Ok cool, yea it seemed to drip durring the high idle setting on the programmer. It could get worst while driving. I figure im going to replace the non servicable oil plug anyway becasue its going to be out and i only feel like doing it one time. Considering it has 245,000 on the block i hope that if this pump was removed befor the mechanic didnt strip any of the small bolts...
nooch450 is offline
post #4 of 9 Old 08-21-2013, 08:18 AM
I did the same when my plug started leaking. Resealed the whole top of the motor. Hpop, oil lines, turbo, fuel bowl, gutted ebpv, etc.
You gotta take it all apart anyway, why not knock it out at once.
2000 F550 CC 2WD
Schnot is offline
post #5 of 9 Old 08-21-2013, 09:17 AM
Arcturus's Avatar
Use a pump to empty the reservoir as much as you can before removing the HPOP. I saw a thread where someone actually used the pump from a hand lotion bottle. Whatever works!
JackT
1996 ECLB 4x4 81k miles
DIY 6637, Hpx, E4OD
First boat Arcturus
2008 Kubota L-39
Arcturus is offline
post #6 of 9 Old 08-21-2013, 09:20 AM
Not a necessity but definitely keeps things a lot cleaner. Keeps you from draining a quart of oil down the back of the block.
2000 F550 CC 2WD
Schnot is offline
post #7 of 9 Old 08-22-2013, 03:19 AM Thread Starter
Should I put a light coat of oil on the new hpop gasket before installing the pump?
nooch450 is offline
post #8 of 9 Old 08-23-2013, 05:47 AM Thread Starter
OK so after cleaning the pump up really well. I was inpecting the mating sufaces from the pump to engine. On the pump there seems to be a few tiny (a few thousanths deep) marcs in the mating surface where the gaskets rubber ring sits. Should i put very tiny dabs of permatex in these little spots to fill them up? Permatex is rated for 10,000 PSI when applied between 2 clamped surfaces... I do not want a leak but at the same time I do not want to cause myself more issues...
nooch450 is offline
post #9 of 9 Old 08-24-2013, 03:01 AM
I don't think it could hurt as long as you don't over do it.
2000 F550 CC 2WD
Schnot is offline
