95 7.3 Oil pressure spike no start - Ford Powerstroke Diesel Forum
post #1 of 9 Old 08-20-2013, 02:45 PM Thread Starter
alright so my truck was running perfect went to start it one day.Turned over strong and about every 5 seconds it will try to start ill hear the injectors start moving an all. then it will just quit. I put a new HPOP, IPR,computer, IDM, and tryed the ICP sensor. Nothing changed. Please help this trucks been down for 2 months. when it spike after cranking for 5 seconds the oil pressure is about 800 psi
RushFORD is offline
post #2 of 9 Old 08-22-2013, 10:35 AM
CPS? Fuel pressure while cranking? Fuel bowl full and staying full after cranking? HPOP full and stays that way?
Haulstroker is offline
post #3 of 9 Old 08-24-2013, 03:46 PM Thread Starter
thanks for the response. It has a new CPS and the pressure at the bleeder is 10psi while cranking. fuel bowl is staying full. and not filling up after i drain it. Im think its my 3month old fuel pump in the valley.
RushFORD is offline
post #4 of 9 Old 08-24-2013, 03:47 PM Thread Starter
new HPOP ,IPR ,CPS,computer ,IDM, ICP
RushFORD is offline
post #5 of 9 Old 08-24-2013, 04:13 PM
Cranking pressure in fuel system seems a little low. If the fuel bowl isn't filling back up, either the fuel pump isn't supplying enough fuel or there is a restriction in the supply line.
post #6 of 9 Old 08-25-2013, 01:43 PM Thread Starter
alright so the water separator screen was pretty gunked up. But I cleaned it real good and it still wont fire.. this thing is really starting to confuse me. O and I put fresh fuel pump on it to. Could it be something with the tank pumps? I tried switching tanks and staring , theyre both pretty much full.Thanks
RushFORD is offline
post #7 of 9 Old 08-26-2013, 06:29 PM
Possibly. Are you getting pressure in the fuel system at all?
post #8 of 9 Old 08-28-2013, 02:50 PM Thread Starter
Alright so cranking pressure is about 20psi at the shrader valve. I have a new HPOP,IPR ,ICP sensor,CPS,FPR mod done, clean fuel filter, fresh oil change. Tach moves while cranking,WTS light is good and when i swich tanks they both read different, my question is if im getting a reading from both tank levels does that eliminate tank selector/valve?
RushFORD is offline
post #9 of 9 Old 08-30-2013, 07:11 PM Thread Starter
its got good fuel pressure.but could there still be air in the fuel causing the truck not to start.? It sounds like its so close to starting it will go from the average 200rpm crank to 5-600 like its going to start. Then just keep repeating this. I was thinking it could have been the fuel pump to start then air got in the system and now it wont fire.
RushFORD is offline
