95 7.3 no start - Ford Powerstroke Diesel Forum
post #1 of 4 Old 08-20-2013, 02:38 PM Thread Starter
95 7.3 no start
Help me please!!!!
Truck started to have a slight vibratration while coming into town. Stopped for a bit and started fine no shake. Drove about 2 km vibration started again and gradually got worse. Pulled over shut it off and started it again, still bad engine shake and than died and won't start now.
Changed the cps, passenger side uvch and topped oil in hpop reservoir. Tach moves. Wts light comes on. There are no warning lights on. Has white smoke coming from pipe. No fuses blown.
What do I try now?!?!
canadiangirl is offline
post #2 of 4 Old 08-20-2013, 05:58 PM
Patrick Feeley's Avatar
Quoted: 13 Post(s)
Welcome to the forum!
If you can, measure the fuel pressure when cranking. It should be at least 25 psi at 100 rpm (minimum) crank speed. Also try switching fuel tanks. Is there fuel in the fuel bowl if you remove the top? Cheers!
Patrick Feeley is offline
post #3 of 4 Old 08-21-2013, 02:12 PM Thread Starter
Figured ut problem. Even though the rear pigtail on the outer harness looked fine changed it and she started right up!!
post #4 of 4 Old 08-21-2013, 06:22 PM
Quoted: 13 Post(s)
Excellent! Glad you found the problem. Cheers!
