fuel leak valy is dry - Ford Powerstroke Diesel Forum
post #1 of 3 Old 08-18-2013, 05:10 AM Thread Starter
Bthurz's Avatar
i have a fuel leak i took a closer look yesterday and the vally is dry fuel is driping from inspection plate on transmission and from infront of starter. the line on the back side of the head there is good and dry and back side of motor/ transsion felt dry when i got my hand in there whats my next step.
1997 F350 XLT
Reg cab lb
stock other than
rhino liner
Big Boy Tool Box
mbrb turbo back 4" aluminized
mods to come:
afe stage II
33"s or 35"s and a leveling kit
Bthurz is offline
post #2 of 3 Old 08-18-2013, 08:11 AM
Patrick Feeley's Avatar
Quoted: 17 Post(s)
I would check the lines again where they attach to the back of the heads again. I would also look at the plugs on the back of the heads. Maybe check the fuel lines after they go from the tank switching valve up to the engine. Cheers!
Patrick Feeley is offline
post #3 of 3 Old 08-19-2013, 04:43 PM
Micko's Avatar
Quoted: 4 Post(s)
Yep agree, check the fuel rail end plug banjo bolt oring
Micko is offline
