96 f250 7.3 - Ford Powerstroke Diesel Forum
post #1 of 1 Old 08-14-2013, 02:38 PM Thread Starter
C_gullion's Avatar
96 f250 7.3
Ok, so I drove the truck for a long time ran great put a chip on it and it ran great for awhile then started to get wts light and had to disconnect the battery cables to get to run then one day I went out and after it started it would fall on its face and die it would on run at wide open and it'd stay at low rpms then it finally died completely it blew smoke out when it done that and it hasn't done much since I've changed the pcm and still nothing the tach does move when cranking and it does crank over and got to start and run for about 10 seconds but shut back down afterwards but the oil gauge shows nothing so I checked oil and there was none in it so I put some in it and still no start I'm lost on this truck please help I've also checked fuses and disconnected fuel bowl and still nothing please help!
Corey
96 f250 eclb
Diy intake
Beans diesel 6 pos
4 inch rough country lift
3" diamond eye downpipe
6" mitre cut stack
Blackouts front back and top
Black and chrome hummer wheels
37" mickey Thompson baja claws
C_gullion is offline
