Tensioner replacement - Ford Powerstroke Diesel Forum
post #1 of 7 Old 08-10-2013, 05:00 PM Thread Starter
Any tips on replacing the tensioner. is the hex bolt that holds it in reverse thread?
95 250 2 legger
zf5
all stock besides a stack
97_Stroked is offline
post #2 of 7 Old 08-10-2013, 05:03 PM
FreightShaker244's Avatar
One bolt normal thread, believe its hex, make sure belt is removed before trying to take tensioner off. Nice and simple job to do
Sent from AutoGuide.com App
1995 F-250 7.3 Powerstroke 5 Speed, 6'' Lift. DIY Intake/Napa filter, 4" exhaust.
FreightShaker244 is offline
post #3 of 7 Old 08-10-2013, 07:00 PM
Patrick Feeley's Avatar
Quoted: 13 Post(s)
The tensioner bolt is normal right hand threads and takes a #50 torx bit (IIRC). Use a good quality bit (and make sure it is fully seated in the bolt) as the bolt sometimes corrodes and can be difficult to remove. I shattered one bit before using a better quality one to remove my 97's. The tensioner's pulley has the lefthand threaded bolt. Cheers!
Patrick Feeley is offline
post #4 of 7 Old 08-11-2013, 09:46 AM Thread Starter
I worked on it for a few hours yesterday. The bolt holding it in is NOT coming out. I broke one torx bit and stripped the bolt...@$%! How do you go about removing this stripped bolt. Tried heat already
95 250 2 legger
zf5
post #5 of 7 Old 08-11-2013, 08:33 PM
Quoted: 13 Post(s)
Never got to that point with mine, but maybe you could remove the alternator bracket with the tensioner installed and drill off the head (or maybe get some penetrating oil in from the back side)??? Once the tensioner is removed you might be able to use some penetrating oil (or more heat) on the leftover bolt shaft. Cheers!
post #6 of 7 Old 08-12-2013, 09:08 PM
Quoted: 47 Post(s)
Something like this might do it: http://www.amazon.com/Alden-8440P-Grabit-Damaged-Extractor/dp/B001A4CWHO , if there's one big enough for the stripped-out torx hole. They seem to be more amenabe to allen, torx, etc. fasteners that already have a hole in the head, so to speak, rather than the conventional "easy-out" style extractors that are so infamous for breaking off in the bolt shank.
madpogue is offline
post #7 of 7 Old 08-13-2013, 04:00 AM Thread Starter
Thanks for all of the replies. What ended up doing it for me was a pipe wrench and a breaker bar. But it seems I can't catch a break, as the idler pulley right below the tensioner is stripped too. I AM really clueless on how to go about removing it because there is no way to get a wrench on it. I guess I will have to take an acetylene torch to it..
95 250 2 legger
zf5
