Dead miss on cyl 2 and 4 - Ford Powerstroke Diesel Forum
post #1 of 5 Old 08-02-2013, 05:27 AM Thread Starter
96 f250 no chips or major mods. 430,xxx miles
Dropping off a customer 3 miles from work on my way back, it felt like the truck was lacking power, but nothing terrible. Then it started missing slowly until it was a dead miss. Got it back to the shop (run a service shop, been working on cars for 15 yrs), let the truck idle outside (figured it wasn't going to restart nicely) for about 45 seconds before it shut down. Had the IDM failure code. Got an IDM from the parts house, extreme hard start, still missing, no change. Pulled v/c's off, wires all burned up. Replaced with the kit to repair all the pigtail harnesses and such, finished up, same thing. Very very hard start. Runs like crap. Managed to warm it up enough to get the EOT sensor warm to do a cyl contribution test with the scanner. Cyl 2 and 4 no contribution. Shut down, performed injector buzz test. All buzzing equally. Got tired after being at work for 15 hrs and decided to call it quits and make it home. Half a mile later (only live a mile from work) it was losing power big time again. Pinned in 1st granny gear and couldn't make it up the hill. Pulled into the parking lot, it died again.
When cranking it does sound odd, but I can't put my finger on what it is. I have to find a compression tester for it today, but anyone have any other thoughts?
Head gasket? <- this is what my money is on because of the 2 dead holes... but like I said, no compression tester here yet.
Hole in the piston?
Injector even though its buzzing? Why 2 cylinders then?
I didn't notice the typical coolant coming up through the reservoir like head gaskets. I have no coolant loss...
I was suppose to go camping this weekend. As irritating as this is, atleast I wasn't at 10,500 feet when it happened...
codyj86 is offline
post #2 of 5 Old 08-04-2013, 09:50 AM
rolsmojave3's Avatar
I just went through this. Did you solder your pigtail or use butt connectors? The IDM sees an issue and shuts down the whole bank, that's why you have no power! Unplug the front driver side injector connection and see if it will run a little better (like 6 and 8 are still firing). I've tried butt connecting the pigtails in a pinch and it doesn't work. Solder is the only way to go!
1997 Ford F-350 4x4 SRW regular cab manual trans.
-4.10s, 315/75r16...getting a frame off restoration. Go fast stuff
1996 Ford F-350 4x4 SRW CCLB manual trans. CALI spec
-ATS intercooler, WW2 w/ 1.0 housing/EPBV delete, Comp 910s, SD Efuel, 3.55s, 315/75r16
2002 Ranger FX4 with manual transfer case and Alcoa's
rolsmojave3 is offline
post #3 of 5 Old 08-06-2013, 05:40 AM Thread Starter
Ok, update.
Have replaced valve cover harnesses with new soldered pigtails. Double checked all pin out diagrams. Matching fine. Replaced #2 and #4 injectors. Replaced CSP. Replaced IDM. I have not done a compression test yet because I can't seem to find one short of getting it from my snap-on guy. When I can finally get it started, it's a dead miss still. After the injectors, I thought it was getting better for a minute at idle only, only to be wrong. Test drove it, same problem as before. after putting a load on it (up hill from a stop for a mile or so), it looses power dramatically before finally barely staying running. If I keep it pinned, it will keep going maybe firing on 3 cylinders. If I let off, it dies. Very hard restart. All glow plugs are working fine. My fuel bowl is full of good clean fuel. Crankcase has oil, I can't see any water or separation of fuel. Full to the mark, just changed it maybe 500 miles ago. Blows white smoke like a mad man under load.
HELP! This damn this is driving me crazy!
I will be selling this as soon as it's running. Time for a new truck!
Thanks guys
codyj86 is offline
post #4 of 5 Old 08-07-2013, 07:31 AM Thread Starter
SOLVED!
Mechanical Fuel pump was not putting out enough fuel for the 2 dead holes. fuel would run out going up a hill under load.
codyj86 is offline
post #5 of 5 Old 08-07-2013, 08:25 AM
Gaius's Avatar
Quoted: 50 Post(s)
Nice! How did you find it?
05 F350 Crewcab
98 Jeep TJ - wheeler
Gaius is offline
Tags
missfire , no start
