In need of obs 7.3 guru help - Ford Powerstroke Diesel Forum
post #1 of 15 Old 07-29-2013, 02:35 PM Thread Starter
I have been fighting my truck for over a year, it has no pulling or lugging power. I have had it at a dielsel shop and this is what we have done. I have put a chip on it, have had the injectors checked replaced 3, new ipr, check harness's, new throttlle position sensor, new sensor under dash, new map sensor, new hpop, he says it maintains good fuel pressure. little more about how it acts. The first 1/3 of throttle seems to run good the more you give it the worse it runs, back of to 1/3 throttle and seems to pick up again. Runs decent bare truck put any trailer on it and it falls on its face. The most boost i can get is 7psi will go to 10 when you down shift and hit 3500 rpms
rseals is offline
post #2 of 15 Old 07-29-2013, 02:56 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Checked the turbo? No exhaust leaks?
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 15 Old 07-29-2013, 03:19 PM
Doesn't Even Care
HVAC SuperTech's Avatar
Quoted: 69 Post(s)
You need to monitor icp and see what it is under full throttle. Id almost bet it's a ipr, icp sensor, or hpop related
Sent from AutoGuide.com App
Nick
E99/CC/Lariat/Factory Wide Body Kit
"The Mistress"
Power Hungry Performance HYDRA Chip
Custom Tuned by Bill@PHP, Tony Wildman@Total Diesel Performance and Lars@Gearhead
D66 w/Dieselsite WW2, Full Force 250/100s, Adrenalin HPOP, Built Trans, Walbro Fuel Pump, S&B Intake, 6" Stacks, Leveling Kit, Eagle Alloy Wheels, 315/75/16 Grabber AT2s & Much More
HVAC SuperTech is offline
post #4 of 15 Old 07-29-2013, 03:39 PM
sldghamr's Avatar
I have 96er myself, I have done the following things:
1. disconnected the exhaust back pressure valve
2. replaced the turbo downpipe
3. replace the ICP sensor w/ the IH version.
if you see a light at the end of the tunnel, it's probably just a photon torpedo
sldghamr is offline
post #5 of 15 Old 07-29-2013, 04:16 PM Thread Starter
they put new ipr on it. new hpop. not sure on the icp sensor he said that he had checked and replaced all sensors.
rseals is offline
post #6 of 15 Old 07-29-2013, 06:27 PM
Quoted: 908 Post(s)
Feedback Score: 3 reviews
Sounds like your butterfly in the turbo exhaust flange is stuck somewhat closed.
Corey@CNCFAB is offline
post #7 of 15 Old 07-29-2013, 06:32 PM
Doesn't Even Care
Quoted: 69 Post(s)
I agree. Check your ebpv...
Nick
"The Mistress"
post #8 of 15 Old 07-29-2013, 07:01 PM Thread Starter
when we put the smaller turbo housing on did away with the back pressure valve
rseals is offline
post #9 of 15 Old 07-30-2013, 07:51 AM
Doesn't Even Care
Quoted: 69 Post(s)
Still need to monitor icp. Also, unplug your icp sensor. It will make the ipr go full open. See if that changes anything. You checked the fuel filter? How's the air filter?
Nick
"The Mistress"
post #10 of 15 Old 07-30-2013, 08:45 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 57 Post(s)
EBP sending unit dead or full of chit. also remove the sending tube and clean it out. If the PCM can't see the exhaust's backpressure it will retard fuel delivery to save the engine. Also check the MAP delivery line for cracks. The PCM uses the MAP to determine how much fuel to give the motor. As much as I love talking with diesel techs these trucks are usually too old for the common tech to know much about them.
Matt
-'97 Mini Monster
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-'15 F350 6.7L DRW 4x4
BigFuel is offline
