Vacuum Pump & Pulley Problem - Ford Powerstroke Diesel Forum
post #1 of 3 Old 07-29-2013, 12:22 PM Thread Starter
WVaMatt's Avatar
I recently bought my PSD with 318,000 on the clock, and I've been working through fixing some things that the PO messed-up. A week ago, my serpentine belt went out while traveling on the highway, so I replaced with a new one from NAPA, and made sure to triple-check the diagram under the hood to route the belt properly. About 20 miles later, I notice a clanging noise from under the hood. Since I was about 0.5 mile away from my house, I drove home and parked the truck, and this is what I find under the hood. The pulley to the vacuum pump is almost totally off the pump!
From what the previous owner told me, he recently replaced the vacuum pump. My question is: how is the pulley attached to the vacuum pump? Is it install using a press? I've included some pictures...is it possible that whoever replaced the vacuum pump just simply did not press the pulley on hard enough? This seems odd to me.
1997 Ford F250 Super Duty PSD
7.3L DIT PowerStroke Diesel
WVaMatt is offline
post #2 of 3 Old 07-29-2013, 01:05 PM
Patrick Feeley's Avatar
Quoted: 13 Post(s)
The pulley is installed and removed using a "power steering pump pulley" installer/remover like this one: OEM/Pulley puller installer kit (27031) | Power Steering Pulley Puller/Installer | AutoZone.com
The PO may not have installed correctly (they usually won't come off). Cheers!
Patrick Feeley is offline
post #3 of 3 Old 07-30-2013, 09:57 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 44 Post(s)
Do not use a press to install the pulley. You will damage the guts in the pump. Like Feeley said, only use a PS shaft press tool.
Matt
'97
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-Oh, and a 2015 F350 6.7L DRW 4x4
BigFuel is offline
