Bad icp? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 07-16-2013, 03:53 PM Thread Starter
97Strokin''s Avatar
Bad icp?
My 97 has a shake at idle and sometimes at start up it lopes until you hit the throttle any ideas
1997
F250
3" DP"
4" exhaust
5" Tip
TS 6 Position
17" AR Rims
4" lift
97Strokin' is offline
post #2 of 7 Old 07-16-2013, 03:57 PM
Colin7.3's Avatar
Could be ICP. Or it could be a sticky ipr
Colin S. Age:22 Certified Diesel Tech, Infantry US ARMY
E99 7.3 6spd 4x4 6637, 4" straight pipe, 365,000 miles
"wear your high mileage as a badge of honor"
04 GMC 2500 4x4 Duramax/Allison
Colin7.3 is offline
post #3 of 7 Old 07-16-2013, 04:45 PM Thread Starter
97Strokin''s Avatar
Anyway to test without throwing parts at it?
1997
F250
3" DP"
4" exhaust
5" Tip
TS 6 Position
17" AR Rims
4" lift
post #4 of 7 Old 07-17-2013, 06:37 AM
Colin7.3's Avatar
Unplug the ICP. See if that helps.
Also you'll need to read HPOP pressure to diagnose the ipr and see the ipr duty cycle
Colin7.3 is offline
post #5 of 7 Old 07-17-2013, 07:01 AM Thread Starter
97Strokin''s Avatar
Unplug it and see if it helps?
1997
F250
3" DP"
4" exhaust
5" Tip
TS 6 Position
17" AR Rims
4" lift
post #6 of 7 Old 07-17-2013, 07:26 AM
Colin7.3's Avatar
Yes unplug the ICP connector and see if the rough idle goes away.
The computer defaults to a reading of 2200 psi. That will tell you if the ICP is causing it rough idle and such
Colin7.3 is offline
post #7 of 7 Old 07-18-2013, 06:17 AM Thread Starter
97Strokin''s Avatar
Can you drive it with the icp unplugged?
1997
F250
3" DP"
4" exhaust
5" Tip
TS 6 Position
17" AR Rims
4" lift
