Bad Engine Sputter - Ford Powerstroke Diesel Forum
post #1 of 3 Old 07-13-2013, 11:07 AM Thread Starter
Bad Engine Sputter
Hey guys,
so im hoping someone here has seen something like this before, but over the winter the power went out and my truck froze as a result, ended up breaking the fuel pump trying to get it running again.
Fuel pump has been replaced and all hoses were also replaced, i currently have no leaks that i can see, and believe me i have looked.
What is happening is what while driving, between 1600-2000 RPM the trucks starts sputtering quite violently. It runs fine before and after that specific range. I have tried driving it like i stole it as i read that that seems to be the consensus on getting air out of the lines... its still happening.
because it is always in the same range i was wondering if it could be something else?
And the truck is not throwing any codes, but something is wrong.
any help will be appreciated!
thanks!
MetalKrook is offline
post #2 of 3 Old 07-20-2013, 05:02 PM Thread Starter
Do you think it could be the HPOP? or could my timing be out maybe?
post #3 of 3 Old 11-25-2013, 03:15 PM Thread Starter
just so i throw it out there. My problem was i filled up with a really bad batch of fuel, and i ended up with a crudload of water in my tanks. drained some fuel and you can see it in there. dropping the tanks this weekend to clean it all out.
Tags
sputter , sputtering
