Fuel pressure reg does not have spring or plunger? - Ford Powerstroke Diesel Forum
post #1 of 1 Old 07-11-2013, 11:26 AM Thread Starter
cthom388's Avatar
So the other day i started to do the fuel reg shim mod with a bb. I removed the plug and the spring and plunger was not in there? I dont know if anybody might have any insight as to why and if that is bad. It has a new superduty electronic pump and it uses a banjo block so the original fuel filter canister is in use. I put a gauge on it and it runs at about 80 psi.
1995 F250 4X4 Zf5
  • TS 6 POS Power-Struck Tunes
  • 3" Silverline Dp to Straight Pipe
  • Custom E-Fuel/Regulated Return
  • 6637 Intake
  • Stage 2 180/100's
cthom388 is offline
