Sum Beach ........... - Ford Powerstroke Diesel Forum
post #1 of 26 Old 07-02-2013, 04:22 AM Thread Starter
Ranzan's Avatar
Quoted: 22 Post(s)
I am thinking i blew out an injector seal but i will see what you guys think
I put new stage 1 DDP injectors in 10k ago along with GP UVCH and relay also fixed some typical wiring issues
also put in new ICP and IPR
truck is a manual with 4:10s
last week i had a few issues with hot starts on my truck long cranking and white smoke
it was a long weekend here so took the my wife and kids camping about 80 k away from our place
got home yesterday afternoon and as i was parking the truck she started blowing black smoke
it now has no hot start issues but is smoking heavy.. she seems to be idling fine and not missing under throttle
Wes
2010 F350 CCLB 4x4 Lariat Sterling Grey
11 and up Console upgrade
Fully deleted DFC Long Block
2 1/2 levelling kit
1995 F350 CCLB XLT Stock for now....
1997 F350 CCLB 4x4 5 speed Tourmaline green
DDP Stage 1`s
08 Bucket console upgrade ( SOLD )
Ranzan is offline
post #2 of 26 Old 07-02-2013, 07:26 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 50 Post(s)
Blown injector seal is usually a white/grey smoke and sounds like the engine sucked a valve. Black smoke can be a cracked nozzle or a stuck EBPV. Open the hood and reach back to the turbine side of the turbo. Put your hand under the extension tube between the turbo and DP and pull the "arm" straight down to remove it from the EBPV. With the arm removed see if the nipple that it was on swings smoothly from as closest to the turbo as it will go and then away from the turbo. If that is working normally leave it close to the turbo and start the truck. Is the truck still smoking? On the valve cover closest to the valley there are two connectors on each head. pull one at a time and see if the smoke goes away with only that one connector removed. If one of the connectors stops the smoking (at least drastically) then the issue is one of those two injectors. With the connector removed look inside the connector and VC plug to see for oil and/or burned pins.
Matt
-'97 Mini Monster
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-'15 F350 6.7L DRW 4x4
BigFuel is offline
post #3 of 26 Old 07-02-2013, 02:29 PM Thread Starter
Ranzan's Avatar
Quoted: 22 Post(s)
thanks bigfuel was going to unplug my injector harness to isolate it i will also check EBPV
it seems i lied
white grey smoke and smells like fuel
Wes
2 1/2 levelling kit
DDP Stage 1`s
Ranzan is offline
post #4 of 26 Old 07-02-2013, 02:41 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 50 Post(s)
Sounding more like you have popped the middle injector seals then. Engine is trying to burn motor oil. Pull the dipstick, take a sniff, and see if fuel is moving the other way as well.
Call me Matt.
Matt
-'97 Mini Monster
-Stage II trans.
BigFuel is offline
post #5 of 26 Old 07-02-2013, 03:37 PM Thread Starter
Ranzan's Avatar
Quoted: 22 Post(s)
checked the EBPV and no change
oil is not smelling like fuel
disconnected my valve cover harness and also no change
Wes
2 1/2 levelling kit
DDP Stage 1`s
Ranzan is offline
post #6 of 26 Old 07-02-2013, 04:16 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 50 Post(s)
This is going to be one of those problem childs huh. Getting to the point that you are going to need to pull your Valve Covers and watch the motor work.
Matt
-'97 Mini Monster
-Stage II trans.
BigFuel is offline
post #7 of 26 Old 07-03-2013, 03:17 AM Thread Starter
Ranzan's Avatar
Quoted: 22 Post(s)
might be a long night tonight
thanks for the help bigfuel
Wes
2 1/2 levelling kit
DDP Stage 1`s
Ranzan is offline
post #8 of 26 Old 07-03-2013, 06:15 PM Thread Starter
Ranzan's Avatar
Quoted: 22 Post(s)
Well the truck is missing heavy now
Pulled the vc and all are oiling fine
I have a burnt pin on both front harnesses though after only 8 k
Wes
2 1/2 levelling kit
DDP Stage 1`s
Ranzan is offline
post #9 of 26 Old 07-03-2013, 10:11 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 50 Post(s)
What pin is burned. The outer two are the glow plugs.
Matt
-'97 Mini Monster
-Stage II trans.
BigFuel is offline
post #10 of 26 Old 07-04-2013, 04:17 AM Thread Starter
Ranzan's Avatar
Quoted: 22 Post(s)
both are outer glow plug pins
was thinking about this last night on how much oil is coming out of the weepholes in the heads
i would say draining out of the head but not puking out of the heads if that makes sense
i am guessing normal? or should the oil be making a mess with engine running?
a quick video i shot with it smoking
Wes
2 1/2 levelling kit
DDP Stage 1`s
Ranzan is offline
