Diesel Newbie Looking for Help with Diagnosis - Ford Powerstroke Diesel Forum
post #1 of 21 Old 07-01-2013, 02:33 PM Thread Starter
97 F250 4X4
-292,XXX
-reman tranny 5000k ago
-Check engine light staying on briefly in the mornings during a short drive to the shop (maybe 2 miles). Ambient temp about 75 deg. Gets to shop fine with what seems like an inconsistent engine noise when coasting after release of throttle. Check engine light goes off after maybe 30 seconds of driving.
-Get to shop at 7:00 am as usual. About an hour later I will run out for materials. Will get in start her up, inconsistent engine noise. Throttle to get out of parking lot (maybe 1000k) as coasting to stop sign: Shut down. Will restart immediately and run with inconsistent noises from engine bay when releasing throttle to coast to stop.
-Later in day, no check engine light, no inconsistent idle.
-Next day repeat, been about two weeks.
-Additional info: it does seem like that once or twice with constant throttle from the peddle in lower gears she will pick up pace without giving more throttle.
Any help would be GREATLY appreciated. If you guys could recommend a good scanner / diagnostic tool that doesn't break the bank, that would be cool tool.
Standing buy with tool set.
Thanks,
Countryroad.
countryroad is offline
post #2 of 21 Old 07-01-2013, 04:58 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 50 Post(s)
What....kind of engine noise? A whirring / jet engine noise? Rubbing / scraping bearing noise? Clicking / popping noise?
Matt
-'97 Mini Monster
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-'15 F350 6.7L DRW 4x4
BigFuel is offline
post #3 of 21 Old 07-01-2013, 04:59 PM Thread Starter
scraping bearing noise inconsistently
post #4 of 21 Old 07-01-2013, 05:01 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 50 Post(s)
Manual or automatic tranny?
Matt
-'97 Mini Monster
-Stage II trans.
BigFuel is offline
post #5 of 21 Old 07-01-2013, 05:05 PM Thread Starter
Auto. i don't like where this is going Big Fuel. in five minutes no less....
post #6 of 21 Old 07-01-2013, 05:13 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 50 Post(s)
If it was a Manual then this would be a Ford style clutch issue. Since it is not I will redirect and ask you to look under the hood. Look sideways at the Accessory belt system and see if any of the pulleys and/or belt look out of alignment/crooked. Remove the Accessory belt from the front of the motor and spin / tug on all of the pulleys. Test looking for bearing resistance to rotation and play in the bearing causing the pulley to camber out of alignment. same with the water pump. Spin it and grab a fan blade flexing it about to see if the bearing is on it's way out. For ****s and giggles get under the truck between the motor and tranny. There is an inspection plate covering the Torque Converter and Flexplate. Pull it and carefully bump the motor to make sure that all of the TC to Flexplate bolts are still tight.
Have you pulled codes to see what might be stored in the PCM?
Matt
-'97 Mini Monster
-Stage II trans.
BigFuel is offline
post #7 of 21 Old 07-01-2013, 05:33 PM Thread Starter
Replaced belt about a month ago along with the belt tensioner. I checked all spinning parts at that time, but will do so again with special attention to water pump.
I assume that any resistance along the belt line will illuminate the check engine light.
Will also check bolts underneath.
No, I have not checked the codes. In the market for a good yet affordable tool for this.
Thanks for your help.
post #8 of 21 Old 07-01-2013, 05:39 PM
Patrick Feeley's Avatar
Quoted: 15 Post(s)
Cracked flexplate? (doesn't really sound like it, but I'll throw it out there anyway). Cheers!
Patrick Feeley is offline
post #9 of 21 Old 07-01-2013, 07:19 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 50 Post(s)
No worries and Patrick offers good thoughts too. The Check Engine light is a reference to what is happening but often records the side effect of the issue. Say this was a high pressure oil issue. Just because the PCM records a weak injector or low oil pressure doesn't mean that it isn't a IPR, ICP, LPOP, HPOP, blown injector o-rings, bad harness, ect,ect just an example, not likely what you have going on...yet). Knowing the code helps pointing us in a direction is all. Since the light goes away it is also not likely an emissions issue. With that I'm thinking small and working my way up.
You only mentioned the truck stalling once. Is that normal when these things are happening? You don't mention if your truck is chipped, is it? Rule of thumb around here is to first pull the chip and drive it again. Next is to swap CPSs and see what happens. The cam position sensor is a know failure for these engines. Ford sells them in the range of $30, auto store closer to $20 but these engines really prefer Ford or International parts to generic auto stores.
I'm hoping that we are chasing two separate issue as apposed to one. This is why I'm having you chase the easy stuff first. In my mind the only thing that would cause both issues at the same time is a HPOP on its way out. This would also explain the power gain with consistent throttle pressure (best way to see that is with a scanner) or a wheel bearing on its way out. You didn't say anything about slight pulling to the side so I'm going HPOP.
Keep you eye on eBay for a MT2500 or MTG2500. That a K2a key, OBDII connector, and a '99 domestic diagnostic cartrige w/"diesel insight" or a cartrige for '01 or newer is all you need. If you are savvy enough you can get this and more for less than $150. Do not pay more than $225.
Matt
-'97 Mini Monster
-Stage II trans.
BigFuel is offline
post #10 of 21 Old 07-02-2013, 03:05 PM Thread Starter
Howdy,
I appreciate you explaining the why behind it, so I can begin to understand.
No, the truck is stalling more than once. I'll explain below after answering your other questions. Not chipped. Just ordered a new Cam Position Sensor.
Checked serpentine belt today and pulleys no sign of abnormality.
Driving home today and it started to idle rougly while coasting and at standing still. It idled like it was almost choking (no signs of unusual smoke). Pulled in the driveway popped the hood and noticed that the engine was shaking more than normal. Observed for awhile and then turned it off. Waited about 10 seconds turned key position and waited for WTS to turn off: Fired right up, idled with a purr, and NO engine shake. 30 seconds later it shut off without prior warning.
In the market for new scanner, also have shop manuals. I know the German gasser I have, but the powerstroke is foreign to me at this point. I will change that soon, thanks to folks like you all.
