Injector Issues - Ford Powerstroke Diesel Forum
post #1 of 6 Old 06-30-2013, 04:53 PM Thread Starter
Injector Issues
Hey guys, new to Powerstrokes, but not diesels.
Picked up a ECLB 94 with a bad trans, last weekend i replaced that along with the clutch, it's got a SMFL. but that's not the problem...
It hesitates under steady acceleration and while maintaining cruising speed, though not as noticable. I took my IR temp gun and cylinders 2 and 3 both were running about 20* colder after 3 mins or so after a cold start, all others were at 115*, these were at 95*. Ran a poor mans buzz test, cyl 3 clicked like it was supposed to, cyl 2 just sparked (poppet issue?). with the truck having 277k on it do you think tightening the poppet would fix cyl 2? and cyl 3, is garanteed injector at this point?
lemme know what you guys think, thanks
94 ECLB 4x4 Powerstroke ZF-5 277k mi
ttop191 is offline
post #2 of 6 Old 06-30-2013, 06:36 PM
Patrick Feeley's Avatar
Quoted: 13 Post(s)
If you go in there to check the poppet screws, you might as well measure the clearance of the armature plate (with any loose poppets tightened). 0.004" is new while anything less than 0.002" is on the ragged edge of needing injector rebuilds. Cheers!
Patrick Feeley is offline
post #3 of 6 Old 06-30-2013, 09:28 PM Thread Starter
just took off the pass side valve cover, pulled the plug on cyl 3, didnt make a difference at all, but i did notice only cyl one was squirting oil...was the reason for that?
ttop191 is offline
post #4 of 6 Old 06-30-2013, 11:28 PM Thread Starter
Replaced the #3 injector, truck is running great, realized all the injectors were squirting oil, just #1 was missing the deflector...how big of a deal is that? as for cyl 2 failing the buzz test i don't know where to go with that, because the truck is running like it should...
ttop191 is offline
post #5 of 6 Old 07-01-2013, 09:41 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 44 Post(s)
Some coils just don't sound like others. It's a test, not a conclusion. If you are really worried about #2 get the engine hot and do a continuity test on that coil. Report your number. Deflector isn't an issue. Just tries to keep oil from blowing all over and these engines don't really do that.
Matt
'97
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-Oh, and a 2015 F350 6.7L DRW 4x4
BigFuel is offline
post #6 of 6 Old 07-01-2013, 12:55 PM
Quoted: 13 Post(s)
If you want to get another deflector spout:
Injector Oil Deflector Spout
(Ford) F4TZ-9G524-A
(International) 1816111C3
MSRP at Ford is $9.17, but you can find it for $6.05 from some online dealers. Cheers!
