why won't my truck work?!?! - Ford Powerstroke Diesel Forum
post #1 of 6 Old 06-27-2013, 05:35 AM Thread Starter
Unhappy why won't my truck work?!?!
okay so when i turn my key nothing happens at all, to get it to start i have to use a screwdriver to skip the solenoid on the fender to get it to crank. so i replaced that solenoid, checked the grounds i could think of and i replaced the starter but nothing seems to work i am stumped any help would be greatly appreciated thanks.
1992 F250 Custom
7.3L IDI 5sp manual
Ford7.3IDI is offline
post #2 of 6 Old 06-27-2013, 08:22 AM
c69ss396's Avatar
sounds like the clutch interrupt switch is bad...
Dieselsite/Strictlydiesel Efuel, Baby Swamps, Adrenaline HPOP, D66 w/1.0 Housing, ww2, International Uppipes, Swamps tunes, Swamps IDM, Tymar Intake, 5in Exhaust, 203* T-Stat, Aluminum Radiator, 6.0 Fan, Dieselsite Coolant filter, Luk Clutch
c69ss396 is offline
post #3 of 6 Old 06-27-2013, 08:44 AM Thread Starter
okay how do i check and replace that?
1992 F250 Custom
7.3L IDI 5sp manual
post #4 of 6 Old 06-27-2013, 08:53 AM
c69ss396's Avatar
look at your clutch pedal linkage and you will see the switch, just jump the 2 wires together and see if it starts, Also did you check all of your fuses?
c69ss396 is offline
post #5 of 6 Old 06-27-2013, 08:57 AM Thread Starter
okay i will try that and yes i have checked all fuses
1992 F250 Custom
7.3L IDI 5sp manual
post #6 of 6 Old 06-27-2013, 09:37 AM
Quoted: 43 Post(s)
If it starts when you jumper the switch, that does NOT necessarily mean the switch is bad. The more likely scenario is that there's excessive wear on the pedal box bushings, and/or the bushing between the pushrod and the stud on the pedal arm, therefore the pushrod isn't moving enough to activate the switch. The bigger problem with this is that it does not fully disengage the clutch. If you let the wear on the pushrod bushing get excessive, it'll grind on the pushrod eyelet and expand ("oval out") the eyelet, and you'll have to replace it, or modify it with a Heim joint.
madpogue is offline
