Need help. Can't figure out the problem on obs 7.3 - Ford Powerstroke Diesel Forum
post #1 of 7 Old 06-22-2013, 03:24 PM Thread Starter
I'm helpin my friend with a late 94 7.3 power stroke, 4wd ext cab 250. First off, is the sensor in the 10 o clock position on the front of the motor the cam sensor or the crank sensor. Second the truck runs fine as long as its cold. When it warms up its starts bucking and missin and will shutoff. Now I've tried two different new cam sensors. When I put them on it would run. It would fire once or twice then not run. Tried two new cam sensors from two different stores, neither fixed the problem, Only made it worse. Put the old one back on and it cranks and runs fine until the oil warms up to 203 degrees. So I hook up a scanner and pull four codes and ran a buzz test. I pulled codes P1219 P0344 P0605 P1280. One code is for the cam sensor, one for icp sensor, one or the PCM or something and then one for cylinder identification. I looked at threads and never could find one that had all these codes at once. Any help is appreciated. I'm a pretty good mechanic and I know how to work on 7.3's as I've done it before but this one is completely stumping me
Jtm9947 is offline
post #2 of 7 Old 06-22-2013, 03:28 PM Thread Starter
And another thing, I watched the icp pressure reading at idle an it was at 580 warm engine. If the motor doesn't die while idling it'll start like loping and the pressure varies between 3 and 600. Sometimes if you try to rev it up alittle the psi spikes almost to 2000 psi. If I unplug the icp it'll idle normally, but it still will buck and misfire when you drive it. Am I having two different problems that are compounding into one big one or what. Btw the truck has 240k miles on it
Jtm9947 is offline
post #3 of 7 Old 06-22-2013, 03:32 PM Thread Starter
I also checked the ipr duty cycle I think and it read 15% so I'm pretty sure that means it has good injector o rings. I need to get this fixed because this is a good strong running truck with no blow by an no leaks. It also has a 6 way chip from kt performance
Jtm9947 is offline
post #4 of 7 Old 06-22-2013, 05:27 PM
Quoted: 43 Post(s)
It's the cam sensor. There is no crank sensor. Aftermarket CPS are known to be junk. Try one from an International or Ford dealer.
Do you see any oil on the ICP connector when you unplug it?
Gotta ask - how old is the oil, and how's the level?
madpogue is offline
post #5 of 7 Old 06-22-2013, 09:51 PM Thread Starter
Ok thanks on the cam sensor. There was some confusion in the parts crossreferencing. There was no oil in the icp connector and it has a fresh oil change and its full but it was a few thousand miles overdue
Jtm9947 is offline
post #6 of 7 Old 06-23-2013, 02:23 PM Thread Starter
About to put a motor craft cps in it and see if it'll run
Jtm9947 is offline
post #7 of 7 Old 06-23-2013, 04:28 PM Thread Starter
Well after 3 different cam sensor, the motor craft sensor is the only one that works and it is so far working perfectly fine and throwing no codes. I guess it was the cps after all
Jtm9947 is offline
