No start issue - Ford Powerstroke Diesel Forum
post #1 of 9 Old 06-16-2013, 11:34 PM Thread Starter
whiteout94's Avatar
No start issue
94.5 PSD 5 speed 84k miles, completely stock. HPOP empties after cranking, No smoke while cranking, tach moves, WTS light comes on, swapped IPR and IDM from my other 94 PSD, did an oil change (had wrong oil filter, possibly one from a IDI) and still can't get it going. Thought I'd post this b4 I went any further. Previous owner tried using ether, :thumbdown:, and replaced glow plugs and vc gaskets b4 giving up and selling to me. There does seem to be a slight oil leak right below the HPOP res. At the inspection cover? So far its been only me working on this thing so I haven't been able to check some things while turning the key but any advice would be appreciated!
ID:	126090   Click image for larger version
ID:	126098   Click image for larger version
1994.5 F350, 4x2, CCLB, ZF5 South Bend Clutch, Diamond Eyes 3" DP-5" Straight Pipe, DIY 6637 intake, ISSPRO EV2 Gauges, 08 Rear Diff Cover, DieselSite Coolant Filter, EBPV and pedestal delete, Riffraff HPx, DIY EFuel, 7.3 SD intercooler
1994.5 F250, 4x2, ECLB, 189k, 5 speed, SOLD
whiteout94 is offline
post #2 of 9 Old 06-17-2013, 03:51 AM
Quoted: 5 Post(s)
So the reservoir stays empty, as in you have to manually refill it?
Originally Posted by Ianstew
There is a difference in a government acting responsibly within their powers, and a government that just decides what their powers are and what responsibility means based on political whimsy.
ianstew is offline
post #3 of 9 Old 06-17-2013, 08:15 AM Thread Starter
whiteout94's Avatar
Yes. So I wanna say that the LPOP isn't doing its job buy b4 I go throwing money at this thing I was just seeing if anyone else had any other ideas on what it might be.
post #4 of 9 Old 06-17-2013, 08:43 AM
JBRIXEN's Avatar
do you see oil pressure on the gauge while cranking?
has it had a hpop recently? the 94.5-95 pumps differ from the 96+ pumps.
95 F350 CCLB, ZF5, 6637, MBRP dp to 4", GTP38, intercooled, 3" plenums, DIY E-FUEL, TE17*, TS 6 pos, 140v IDM, boost fooler, leveling kit, 315/75/16's, boost, pyro, oil temp
JBRIXEN is offline
post #5 of 9 Old 06-17-2013, 08:34 PM Thread Starter
whiteout94's Avatar
Seeing NO oil pressure on the gauge while cranking it, doesn't even jiggle. As far as I know its the original HPOP. I'll give the guy I bought it from a call sometime this week and see what else I can find out about this thing
post #6 of 9 Old 06-18-2013, 08:22 AM
JBRIXEN's Avatar
sounds like a lpop. put a mechanical gauge on to verify.
JBRIXEN is offline
post #7 of 9 Old 06-18-2013, 09:14 AM
Quoted: 5 Post(s)
Agreed. LPOP.
ianstew is offline
post #8 of 9 Old 06-18-2013, 11:15 AM Thread Starter
whiteout94's Avatar
Got a melling lpop on order, should b here tomorrow. I'll keep u guys posted, thanks for the help
post #9 of 9 Old 06-24-2013, 06:04 PM Thread Starter
whiteout94's Avatar
Just wanted to update this real quick. Got the new LPOP installed yesterday and everything put back together tonight. After cranking it 3-4 times she fired right up! Just wanna thank everyone again!
