CCV Problems! Help!! - Ford Powerstroke Diesel Forum
post #1 of 10 Old 06-16-2013, 10:37 AM Thread Starter
Powerstrokenation1995's Avatar
Quoted: 43 Post(s)
Alright fellas! i need some help here, recently my truck has been pissing oil off the oil pan and bell housing, makes it look like a rear main seal. i know it is not though, i have traced it back to the ccv. ive been looking at doing the ccv mod for a while but i think that it is past just doing a mod, i need to get a new ccv for it first as the current one appears to have blown every seal imaginable in it and is leaking from everywhere. in there lies a problem, i have looked everywhere i can think of and cannot seem to come up with a new or reman ccv. do any of yall know where to find one? suggestions would be greatly appreciated and while we're at it, what is the best ccv mod out there?
Thanks y'all!!
Kris out...
=Kris=
1995 F250 7.3 PSD - Gone but not forgotten.
2004 f250 4x4
Straight pipe...
Thats all...
Boring, right?
Stay tuned!!
Powerstrokenation1995 is offline
post #2 of 10 Old 06-16-2013, 10:56 AM
ThomasvillePavers's Avatar
On my 2000 the CCV (crankcase vent) is just a hose that connected the leftside valve cover to the air inlet to vent, there are no parts besides a rubber elbow and tube which you can replace with any oil resistant hose. Can you take some pictures of what you found that is leaking oil heavily? that would help us alot!
-Brad
00' F350 CC DRW still pushing well past 300K: 6637, GTP38R, 5.6k mod on turn dial, superchips, trans command, Torque pro on Galxy S2 for PID monitor, OD lock, 4" straight pipe, condensor cooler w/electric fan, watersprayed intercooler, 08' taillights, 05' headlights, BD valve body kit, all door locks foiled, full LED exterior light kit, and the list is still growing.
ThomasvillePavers is offline
post #3 of 10 Old 06-16-2013, 11:24 AM Thread Starter
Quoted: 43 Post(s)
yessir, here ya go
ID:	125538   Click image for larger version
ID:	125546   Click image for larger version
ID:	125554   Click image for larger version
=Kris=
2004 f250 4x4
Straight pipe...
Thats all...
Boring, right?
Stay tuned!!
post #4 of 10 Old 06-16-2013, 11:32 AM Thread Starter
Quoted: 43 Post(s)
its on the driver side valve cover, right near the brake booster. if i park it for an hour or so, i have a slightly smaller than baseball sized drip mark.
=Kris=
2004 f250 4x4
Straight pipe...
Thats all...
Boring, right?
Stay tuned!!
post #5 of 10 Old 06-16-2013, 11:48 AM
Undead Member
gaspipe's Avatar
Quoted: 7 Post(s)
You might have two things (or more going on). The CCV box attaches to the valve cover with two phillips screws. There are two o-rings between the CCV and the valve cover that tend to go bad. This usually makes for oil on the oil cooler or the oil filter. I'd start here first, it's easy.
The oil coming off the back of the motor is more likely from the EBPV and/or the turbo pedestal o-rings. Rear seal leaks are fairly uncommon.
dieselorings.com has the orings.
~Bruce~
'95 F250 4x4 ECLB 300k - ZF5, Southbend, 4.10, van pedestal, EBPV & CCV delete, 1.0 ex housing, 3" DP, 4" exhaust, BFAF, 6.0 fan, 140v IDM, Autometer, MagHytec diff cover, HD ft springs, 16x8 alloys
'95 F-Superduty 4x2 CM 12' Flatbed 47k - E4OD, 5.13, Banks intercooler, van pedestal, EBPV & CCV delete, 1.0 ex housing, 3" DP, 3.5" side dump exhaust, BFAF, PHP tunes, 6.0 fan, 140v IDM, TruCool, MagHytec diff/pan, Dieselsite ext trans filter, Autometer, 180w LED bar
gaspipe is offline
post #6 of 10 Old 06-16-2013, 12:07 PM
He is right on the money, that box that attaches to the valve cover will be easy to reseal with new orings, I found some for our '95 at our local napa, I took the old ones off and they matched them up in less than 2 minutes. I think it was a total of $2
-Brad
post #7 of 10 Old 06-16-2013, 12:52 PM Thread Starter
Quoted: 43 Post(s)
i replaced them twice already, it started leaking out of where the bottom of the vent connected to the top of the vent. i jb welded it but it ate through that too. so i kinda just need to get a new one.... as far as the oil goes, i can see the run mark of oil running down the back of the motor coming from the bottom of the drivers side valve cover and it runs down, splits off (some of the oil runs down the oil filter and anything near it) and some runs right in between the oil pan and bell housing and then comes out on both.
=Kris=
2004 f250 4x4
Straight pipe...
Thats all...
Boring, right?
Stay tuned!!
post #8 of 10 Old 06-16-2013, 03:58 PM
Undead Member
gaspipe's Avatar
Quoted: 7 Post(s)
If I were lucky enough to have a boogered up CCV housing, I think I would remove the valve cover and weld in a pair of 90 degree elbows to the valve cover. One to send to a breather box, the other as an oil return. IMHO, the OE breather is marginally sized, especially for an aging diesel.
How the two swedged halves of your CCV got loose is a mystery. You could always degrease the part, then use something like permatex ultragrey or Hondabond ht to re-seal it, or have a buddy tig it together.
~Bruce~
gaspipe is offline
post #9 of 10 Old 06-25-2013, 02:24 PM Thread Starter
Quoted: 43 Post(s)
Sounds like I'm about to have some fun on this project....
Real quick unrelated question, Bruce, I noticed in your SIG that you have the idm mod on your f super duty. How do you like that? What exactly does it change?
=Kris=
2004 f250 4x4
Straight pipe...
Thats all...
Boring, right?
Stay tuned!!
post #10 of 10 Old 01-14-2014, 02:28 PM
I am a new member to the forum, but have had the privilege of reading all the excellent knowledge shared here.
I recently have been trouble-shooting starting problems on my 1997 F250 7.3L 4x4. In the mean time I performed the Crankcase Ventilation (CCV) modification for under $40with excellent results. I took the time and documented the steps along with several photos. I have not figured out how to upload the document (PDF) since I am just a standard member. So I have stored the document out on my personal website and created a link to open the document. I hope the information helps others who have questions about the CCV modification. Thanks!
http://www.wafenterprises.com/1997_7-3L_PSD_CCV_Mod.pdf
Let me know if you have issues opening the link.
wfidler is offline
