Fuel problem? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 06-15-2013, 01:29 AM Thread Starter
Quoted: 37 Post(s)
Fuel problem?
Sunday night I was heading to a buddies house (about 30 miles) and my truck started doing this thing where it seems like the filter is clogging/not getting enough fuel. It's loses power and makes a noise. (I guess it's the injectors clacking from no fuel+cylinders "dry firing")
So I pulled over and tried draining the filter. Not sure if anything at all came out. (It was dark and I didn't have a light) But it then quit doing it.
So Tuesday comes around I'm heading to my gf's parents house (maybe 7 miles) and it does it again. About ways there. So same thing, I pull off and try to drain the filter, but this time I have a bottle I drain it into. At first hardly anything came out so I shut it off, then got it to drain. All kinds of crap in it. Looks like rust/dirt.
So I head on and make it about a mile and it's doing it again, but this time actually died. So I finally got it started after a lot of cranking and switching to the front tank. Put $40 in fuel in at qt of the way, and it did fine the rest of the way.
When I got there I changed the filter and let it run for a bit.
Later when I went to leave, it died again at the entrance of the neighborhood. Cranked awhile again and got it started.
Well yesterday (Friday) I'm heading back to her house, and it does it again at about the same spot, just not as bad. So I slowed down and kept going, and it quit doing it.
On the way home, same thing but at the mark this way. Slow down into town and it quits doing it.
Drained it again but it's fairly clean. Just a few specs in it.
A few months ago I relaced the fuel pump with an airtex from autozone, which I believe is made by carter. When I replaced it, it had same symptoms leading up to failure, but it was all in the same day, and I believe was caused by a non venting fuel cap.
When I had it apart, I cleaned all the screens and the bowl itself.
There don't seem to be any leaks in the valley. The drain hose leaks when I open it. So I need to dry it up, then run it to see if it comes back while running, or only when I open the drain valve.
Does this sound like another failing pump? Or what?
I hate to change it again just to put another failure prone mechanical pump on, but as long as it gets me a few weeks to collect everything for an e-fuel setup, I would do it.
This is my 94 PSD.
I've been pumping fuel from my brothers truck being as his engine is blown, but his showerheads are broke off, so I don't see how I could've picked up trash from his tanks.
This all started running on the rear tank, which is plastic on my truck. My front is metal though.
Also I changed the oil Wednesday with TSC traveller 15w-40 all fleet diesel oil and mobil 1 filter.
Changed the rubber fuel lines between the pump and filter a few weeks after changing the pump.
Also no longer have the restriction sensor since they're so leak prone. I used a pipe plug and some sealant.
Tomorrow I'm going to see if I can find a fuel pressure gauge, or rent one of the testers.
1994 F350 7.3 PSD 4X4 ZF5 DUALLY
PHP HYDRA, 6637, 3-4 DP TO STRAIGHT 4 BEHIND THE TIRE, 1.0 EXHAUST HOUSING, DIY D66 TURBO, FUGA E-FUEL, EBPV DELETE. Cooper discoverer AT/3'S.
2010 VW JETTA TDI DSG Kerma tune. Hankook ventus v2 concept 2.
79jasper is offline
post #2 of 9 Old 06-21-2013, 03:21 AM
Micko's Avatar
Quoted: 4 Post(s)
Did you find the problem yet? Did you say you cleaned your fpr completly? I am interested to know the cure. Thanks
Micko is offline
post #3 of 9 Old 06-21-2013, 10:52 AM Thread Starter
Quoted: 37 Post(s)
Turns out my tank pickups were broke off. And a piece got in the fuel line somewhere.
79jasper is offline
post #4 of 9 Old 06-21-2013, 07:03 PM
Micko's Avatar
Quoted: 4 Post(s)
Thats a tough one! Thanks for the info!
Micko is offline
post #5 of 9 Old 06-21-2013, 10:00 PM Thread Starter
Quoted: 37 Post(s)
I'm ordering a fuel pressure gauge tomorrow. It still seems to lack a little power at times, so I want to keep an eye on it.
Walbro makes new tank pickups that I plan on using eventually. Walbro mp-12 or mp-13, still deciding which.
Are you having problems with yours? Or just wandering for future reference?
79jasper is offline
post #6 of 9 Old 06-22-2013, 06:18 AM
Micko's Avatar
Quoted: 4 Post(s)
Just reference. But I currently have my engine on the stand to replace the oil pan. While I have the engine out, I'm also doing a list of other things including fuel bowl, fuel pressure regulator, and IPR --teardown cleaning & new O rings. Issues with those items could cause similar symptoms to yours I think, just interested incase I screwed up with reassembly .... I'll know where to look. Thanks, and good luck. It will be interesting to see what returns you to full power.
Micko is offline
post #7 of 9 Old 06-22-2013, 07:00 AM
Micko's Avatar
Quoted: 4 Post(s)
After reading your post again. When my cps failed, it did the same thing as you are experiencing. I could keep it running by going faster or slower but it would run rough. some times it would just die then take some crancking or if I let it rest, it would start again.
Micko is offline
post #8 of 9 Old 06-22-2013, 07:58 AM Thread Starter
Quoted: 37 Post(s)
I'm definitely wanting to swap a new one. Then keep the old one for a spare.
79jasper is offline
post #9 of 9 Old 05-09-2014, 08:43 AM Thread Starter
Quoted: 37 Post(s)
Just as an update, still going strong.
Did end up swapping the CPS, runs a bit better.
Do have some slight fuel weeping in the valley though.
And I did blow the drivers return line. Lol fun fun.
79jasper is offline
