Leaking fuel bowl? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 06-14-2013, 01:36 PM Thread Starter
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Leaking fuel bowl?
Hey OBS guys i need your input on this truck
1995 7.3 Powerstroke Dually 2wd
He says it has a leaking fuel bowl what could that be and is it common and easy to fix like he says?
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #2 of 7 Old 06-14-2013, 01:44 PM
blue99stroker's Avatar
Quoted: 249 Post(s)
its common. dieselorings sells new orings for like 6 bucks.
just make sure its leaking from their, the fuel drain valve is on the back of the bowl.
if its not leaking from the drain valve he sells a kit for the other orings and such.
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #3 of 7 Old 06-14-2013, 01:47 PM Thread Starter
Chapter Director
Quoted: 5 Post(s)
Sweet so it would be a good trade for my v10 dodge in my sig?
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #4 of 7 Old 06-14-2013, 01:55 PM
66Bronco's Avatar
If it's not the orings, the WIF sensor will also leak. Just remove it and put in a pipe plug.
'95 F-250HD
ZF 5-Speed 13'' clutch w/ SMF conversion
B&W Gooseneck
Custom Spare Tire Mount
66Bronco is offline
post #5 of 7 Old 06-14-2013, 02:02 PM Thread Starter
Chapter Director
Quoted: 5 Post(s)
Sounds like id be fine pretty easy enough fix?
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #6 of 7 Old 06-14-2013, 08:11 PM
Patrick Feeley's Avatar
Quoted: 13 Post(s)
Usually it is the Fuel Restriction Sensor that is the leaker (on the fuel pressure regulator on 96-97's and on the back of the fuel bowl near the bottom on 94-95's) that you can use a 1/8 NPT plug. The fuel heater feedthrough is sealed with an o-ring and that is held down by the WIF sensor (also o-ringed IIRC). Note that fuel bowls have also simply rotted out on the bottom on some trucks. Cheers!
Patrick Feeley is offline
post #7 of 7 Old 06-14-2013, 08:16 PM Thread Starter
Chapter Director
Quoted: 5 Post(s)
Well i ended up getting it. it doesnt leak real bad so when i get some time ill try to get some pics of the leak. Im way more familar with the super duty 7.3 so i have some book learning to do
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
