1995 7.3 No start - Ford Powerstroke Diesel Forum
post #1 of 4 Old 06-13-2013, 05:50 PM Thread Starter
1995 7.3 No start
I have a 1995 psd 5spd cc 4x4. It shut off while driving today. I pulled away from a stop sign, got to third gear and the engine dies, I coasted to a stop. I checked the fuses, the wait to start light comes on and the engine turns over , but won't start.
The tach is moving a bit when cranking. I pulled the chip out, and the tach doesn't seem to move much when cranking when the chip is out.
The schrader valve on the fuel bowl didn't seem to have pressure. I opened the drain on the bowl and then idled the truck for a few minutes before leaving the house, I idled it with it closed for a few minutes so I wouldn't have thought that would be the issue.
I towed it home, went by the Ford house and picked up a CPS and a new fuel filter. I installed the CPS and opened the fuel bowl. Bowl was full of fuel. The filter I got was apparently the wrong one for this truck, so I reinstalled the old filter and topped off the fuel. I cranked on it a bit more, still nothing.
I have the charger on the batteries now and am going to try to check fuel pressure when they get a little healthier.
Any ideas?
Jimbo302 is offline
post #2 of 4 Old 06-14-2013, 10:13 AM
atvrider93's Avatar
Quoted: 8 Post(s)
sounds like possibly fuel pump, I believe you need 50psi for it to crank. may be a little less, can't remember
1996 F350 4x4 CCLB-- I'll miss her
1996 F350 4X4 RCLB zf5 213K
6637
OBA w/horn
DE 5"
PHP tunes
Mud Country 315/75/16
2008 Wr250X
Originally Posted by belz View Post
There u go Tom. John may not be sexy, but he can tutor you, lol.
atvrider93 is offline
post #3 of 4 Old 06-14-2013, 10:15 AM Thread Starter
Ok, batteries are good after an overnight trickle charge. I spun it over for a bit, no smoke from the tailpipe and no pressure at the bowl. It was puffing a bit of white smoke under acceleration a few days prior to this.
Good point, I should verify if the pump is working.
Jimbo302 is offline
post #4 of 4 Old 06-14-2013, 09:59 PM
atvrider93's Avatar
Quoted: 8 Post(s)
Just do a simple pressure gauge on the fpr to make sure you're getting sufficient pressure.
6637
OBA w/horn
DE 5"
PHP tunes
2008 Wr250X
