Crank Case Pressure - Ford Powerstroke Diesel Forum
post #1 of 4 Old 06-12-2013, 07:51 PM Thread Starter
gabegoforth's Avatar
Crank Case Pressure
My 95 Project truck has more crank case pressure than what I think it should have. It doesn't puff, but it has just enough to slightly blow by the dipstick. I think the turbos junked, but what about the CCV? I hate to think that the motors dusted, but if I must rebuild it for a school project I guess I will. I'm going to school at SCC to be a Diesel Mechanic. Just wanted to see if there are other causes too. The truck flat moves, no shortage of power. On a side note it has become a really hard starter for some reason. It fires right up if it hasn't set for very long. Kind of like I herd of that oil draining of the injectors or something. When I got it it would fire right up. Faster than my 96, but now its slower. I've stuck less than a hundred miles on it. Thanks for any ideas.
1996 F-350 Crew Cab 4x4, Auto, Toyo MT 315/65/16r, full force 160/30% injectors, Super Duty electric fuel system, RiffRaff regulated return, Driven diesel electric fuel pump controller, SWAMPS HVHF IDM, custom tuned TS chip, 1.0 Turbo, CX Intercooler, 4" Exhaust, 6637 Intake, 4.10 Gears, 225k+ miles.
gabegoforth is offline
post #2 of 4 Old 06-13-2013, 09:36 AM Thread Starter
Bumping it.
post #3 of 4 Old 06-14-2013, 11:16 AM
atvrider93's Avatar
Quoted: 8 Post(s)
flip the oil fill cap over and see if the pressure blows it off. only definitive test is a compression test
1996 F350 4x4 CCLB-- I'll miss her
1996 F350 4X4 RCLB zf5 213K
6637
OBA w/horn
DE 5"
PHP tunes
Mud Country 315/75/16
2008 Wr250X
Originally Posted by belz View Post
There u go Tom. John may not be sexy, but he can tutor you, lol.
atvrider93 is offline
post #4 of 4 Old 06-23-2013, 01:17 PM Thread Starter
I've done that. It can't blow it off. It's a steady stream. No puffs. I'm thinking about testing the turbo. Might explain why I can't get it to quit smoking. I thought it was the injectors, but it could be sending oil out the tail pipe. In the 50 miles I might have driven it it lost about 4-5 quarts of oil. Part of which was due to a hpop rail plug replacement and some other oil leaks, but not that much.
