97 exhaust smoke - Ford Powerstroke Diesel Forum
post #1 of 3 Old 06-12-2013, 02:50 PM Thread Starter
97 exhaust smoke
i have a 1997 f250 wit a 7.3. i bought the truck with 277,000 miles on it, and have had to do very little to the engine, except a few sensors which were replaced preventatively. the truck is now at 307k, and as far as i can tell, seems to be running relatively strong. but one thing i've always wondered about, any other diesel ive run, if you rev up the engine repeatedly, or put a load on it and push it to go, the engine will smoke a little. i have never once seen this truck puff any black smoke out whether it was pulling a load or normal driving. im not complaining about it, i am merely wondering if this is normal engine behavior, especially at 300,000 miles.
97250hdDaisy is offline
post #2 of 3 Old 06-13-2013, 05:52 PM
Mine would do that when the clamp on the downpipe was loose.
Jimbo302 is offline
post #3 of 3 Old 06-14-2013, 01:06 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
It shouldn't smoke at all if its stock the injectors are only 90cc and the turbo is pretty efficient
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
