10 psi boost and truck sit's still then then icp code - Ford Powerstroke Diesel Forum
post #1 of 1 Old 06-09-2013, 06:17 PM Thread Starter
ole96stroker's Avatar
Exclamation 10 psi boost and truck sit's still then then icp code
Just gone done putting 17 degree hpop on my truck now it misses badly, truck does fine when taking off then at 10 psi boost act's like it goes into limp mode then the icp code come's up. Tried unplugging icp and still run's worse.Idle sound's like a fast fast lope. Also in 5th gear cruising it will be doing fine then start missing and blowing blue smoke. help would be thankful im bout to go insane thanks
******1996 ford f250 powerstroke 5 spd 4x4******
***170,000 miles, ts 6 pos, intake, exhuast***
ole96stroker is offline
