occasional stumble - Ford Powerstroke Diesel Forum
post #1 of 5 Old 06-08-2013, 12:55 PM Thread Starter
timmy's Avatar
occasional stumble
Hey guys, could use some help. I have a 96 with a 5spd that on occasion (1-3 times every 50 miles), stumbles as if running out of fuel. I replaced filter, replaced entire housing including FPR seems to happen less now but still happens. I'm thinking either I have a small leak in my fuel line thats drawing air ( nothing is visable ), or there is a screen somewhere thats plugging up. The truck has actually only stalled once and stumbles even at idle once in a while, does the same thing on both fuel tanks. Any ideas or input would be greatly appreciated, thanks
96' f-350 2wd,5spd, C+C w utility body, 370,000miles
timmy is offline
post #2 of 5 Old 06-09-2013, 02:04 AM
sgt dave's Avatar
Quoted: 3 Post(s)
sounds like you need new injectors. a buzz test will tell you how healthy your injectors are
1996 F250 SC/LB, 4x4 PSD, ATS stage 1 trans 5 star tcc, AC codes,TW tunes, magnaflow 4" exhaust, 6637 , FS 2500 bypass oil filter,pure power reusable oil filter, isspro gauges, dieselsite cpr fuel pump system, adrenaline hpop, pml rear diff cover ,ebpv delete,non epbv pedestal, king pin dana 60, swamps idm, tru cool 4739
USMC 1993-1998
Plumbers & Pipefitters L.U.447
sgt dave is offline
post #3 of 5 Old 06-09-2013, 12:36 PM Thread Starter
timmy's Avatar
Sorry, has new injectors and harness no codes either
timmy is offline
post #4 of 5 Old 06-09-2013, 01:17 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
My truck did that every now and then, swapped in a new CPs and runs great now
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #5 of 5 Old 06-10-2013, 10:21 AM
Quoted: 50 Post(s)
^^^^^ +1; Next time it stumbles, watch the tach. If it drops way down, below the actual engine speed (with a 5-speed, the truck's momentum will keep the engine turning), then that fingers the CPS or wiring to it. If it just barely moves, or not at all, then it may be a fuel or other issue (but doesn't rule _out_ the CPS).
madpogue is online now
