1997 Wont Start when hot - Ford Powerstroke Diesel Forum
post #1 of 3 Old 06-03-2013, 05:45 AM Thread Starter
Biggsw784's Avatar
I have a 97 f350 and when cold it has a extended crank before starting but will start. once hot and you kill it, it will not restart. It has actually died going down the road also. I have changed the mechnical fuel pump by the fuel filter housing and also changed the cam sensor with no improvements. My scanner wont connect to the icp or ipr to watch oil pressures. What else can I check for?? Thanks
2008 F250
10" PMF Lift
38x15.50x20 Toyos
20x12 Fuel Hostage
AFE CAI
FLO PRO 5" Turbo-back
"Spartanized"
2004 F350
Leveled out
35x12.50x18 Nitto Mud Grapplers
18x9 Monster Wheels
5" exhaust
Diablo Sport Trinity 2
Big Tex Bed
Biggsw784 is offline
post #2 of 3 Old 06-06-2013, 05:24 AM
I just went through this with a 97' I just baught. My problem ended up being a bad IPR.
WishinIwerFishin is offline
post #3 of 3 Old 06-07-2013, 10:40 AM
Patrick Feeley's Avatar
Quoted: 13 Post(s)
Many time a "no-start when hot" is bad IPR o-rings (it could be other HP oil issues too). The o-ring kit is about $30, so it's a relatively cheap fix attempt. Cheers!
Patrick Feeley is offline
