'96 oil leak help - Ford Powerstroke Diesel Forum
post #1 of 2 Old 06-02-2013, 04:56 PM Thread Starter
'96 oil leak help
Hey guys, I just bought my first diesel ever it's a 1996 xlt. Well yesterday I out driving around and got in the throttle and noticed the check engine light came on. I pulled into a parking lot turned the truck off and back on the the light went off. So when i got home i crawled up under it just kinda on a wim and I saw oil dripping of the tranny oil pan. I looked all around and noticed it was coming off the top of the tranny so I figured it was coming out of the motor somewhere. So I popped the hood and right behind the turbo on the firewall was oil spray and I also noticed some dripping of the passenger side exhaust manifold. Today I cleaned the motor cranked it and let it idle for awhile and held it at about 2k rpm for a few seconds and nothing, no oil. I took it on about a 5 min drive and no oil. Then I went on about a 2 or so mile drive and sure enough it was leaking. So I'm thinking (hoping) the o-rings on the pedestal are bad and letting oil through. The truck has 157k on the clock and has been sitting for awhile. Let me know what y'all think, thanks.
P.s. i've done a lot of searching on other forums and this one is by far the best. All you guys seem like cool dudes and are very helpful
Blowen_coal is offline
post #2 of 2 Old 06-02-2013, 07:00 PM
Undead Member
gaspipe's Avatar
Quoted: 7 Post(s)
Or the seal on the piston on the exhaust back pressure valve failed. O-rings most likely. Fairly common stuff, but a bit of a headache to fix. Not hard, just patience.
~Bruce~
'95 F250 4x4 ECLB 300k - ZF5, Southbend, 4.10, van pedestal, EBPV & CCV delete, 1.0 ex housing, 3" DP, 4" exhaust, BFAF, 6.0 fan, 140v IDM, Autometer, MagHytec diff cover, HD ft springs, 16x8 alloys
'95 F-Superduty 4x2 CM 12' Flatbed 47k - E4OD, 5.13, Banks intercooler, van pedestal, EBPV & CCV delete, 1.0 ex housing, 3" DP, 3.5" side dump exhaust, BFAF, PHP tunes, 6.0 fan, 140v IDM, TruCool, MagHytec diff/pan, Dieselsite ext trans filter, Autometer, 180w LED bar
gaspipe is offline
