rough idle - Ford Powerstroke Diesel Forum
post #1 of 3 Old 05-29-2013, 06:33 PM Thread Starter
rough idle
I have a 96 psd I have checked every thing icp,cps,ipr,ebs,buzz test.Change injector o-rings. It drives ok. No smoke when driving just a puff first start of the day.Checked the fuel pressure and it insanely bounces between 30-90 at idle. Helps please I am at my wits end and getting ready to burn the piece of ****.when it idles feels like the motor is going to jump out.Changed idm,pcm with numerous working ones no change.
crazyjay is offline
post #2 of 3 Old 05-29-2013, 07:09 PM
Patrick Feeley's Avatar
Quoted: 10 Post(s)
Try using a liquid-filled 0-100 psi pressure gauge to measure the pressure. The glycerin in the gauge helps dampen the needle fluctuations. If you are already, then you might want to check the condition of the Fuel Pressure Regulator screens (the usual one for the orifice vent at the regulator to bowl joint, and the mesh screen under the circlip-retained plate where the fuel line goes into the bottom of the regulator). Also check the condition of the regulator spring, bore, and plunger (kinks, scoring, etc). Cheers!
Patrick Feeley is offline
post #3 of 3 Old 05-30-2013, 12:17 PM Thread Starter
got it fixed went to change my fuel reg. Pulled the fuel bowl and bottom fuel line was pinched.Put a new line in idles great now. thanks
crazyjay is offline
