Truck wont crank - Ford Powerstroke Diesel Forum
post #1 of 17 Old 05-27-2013, 12:23 PM Thread Starter
Question Truck wont crank
I started up my truck today and then moved it into that garage to fix some stuff, it started up fine. Then I tryed to move it out of the garage and it will not start. It wont even crank. All I get is a loud click noise. All the lights work and the wait to start also works. please help. All fuses were check under the hood and look fine. Brand new starter less then a year ago.
Rickie Conway is offline
post #2 of 17 Old 05-27-2013, 01:41 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
So it clicks and does not spin?
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 17 Old 05-27-2013, 01:47 PM Thread Starter
I assume it doesn't spin. It clicks then nothing.
post #4 of 17 Old 05-27-2013, 01:50 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
How does the fuel bowl fill if engine isn't turning over?
Tried the CPs, icp, if it is turning over is their any smoke from tail pipe?
If its only clicking you may need a starter
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #5 of 17 Old 05-27-2013, 01:59 PM Thread Starter
yea i'm not sure about fuel bowl. lol yea the starter just makes one loud click. The starter is fairly new, bought it a year ago.
post #6 of 17 Old 05-27-2013, 05:28 PM
Patrick Feeley's Avatar
Quoted: 13 Post(s)
Check ALL battery cable ends for tightness and cleanliness. Have each battery load tested independently. You might want to have the starter bench tested as well. Cheers!
Patrick Feeley is offline
post #7 of 17 Old 05-27-2013, 06:13 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Starter bench testing is a waist of time IMHO, had a buddy have his done, passed with flying colors, swapped in a new one truck started, yours should still be under warranty swap it out
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #8 of 17 Old 05-27-2013, 06:32 PM
jesilvas's Avatar
Quoted: 2 Post(s)
Neutral safety switch possibly.
You need to see if the solenoid (on pass side fender on a SD) is getting fire from the ignition switch.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #9 of 17 Old 05-28-2013, 07:54 AM
Quoted: 50 Post(s)
Automatic or manual transmission? Are you hearing the click when you turn the key to RUN, or when you turn the key to START?
How old are the batteries?
madpogue is offline
post #10 of 17 Old 05-28-2013, 10:55 AM Thread Starter
It is a Manual. It happens when I turn the key all the way forward. MY batteries were replaced less then a year ago. I tested the cable running to the starter and i'm pretty sure its good. It looks like there is fluid leaking from where the starter bolts to the trans.
