7.3 l diesel problem!!! - Ford Powerstroke Diesel Forum
post #1 of 8 Old 05-22-2013, 04:43 AM Thread Starter
Express.1's Avatar
sorry for my poor english (I'm Italian), I have a 7.3 powerstroke ford Ecoline E350 1997, teaching you what happened: in regular gear I had two jerks to the engine and then 2/3 mile has stopped, after about 5/10 minutes again after 5/10 minutes of stopping the engine. replaced filter, clean tanks and floating, same problem!!, externally mounted electric pump set in motion after off attached electric pump will not start but nothing. could be the mechanical pump mounted near the diesel filter? that after a while it stops? electric pump of luck was mounted between the tank and the filter, but if the mechanical pump stops working does not pass diesel right? someone can help me? thanks Sergio
Express.1 is offline
post #2 of 8 Old 05-22-2013, 09:21 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
If you dropped the tanks have you had a chance to prime the system? And have you checked fuel psi while cranking?
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 8 Old 05-22-2013, 11:33 AM
Patrick Feeley's Avatar
Quoted: 13 Post(s)
If you can, measure the fuel pressure at the shrader valve (driver's side of the fuel filter bowl) while cranking. The specification is 25 psi minimum and minimum 100 rpm cranking speed. At idle (if you can get it to idle), it should be 50-60 psi. Cheers!
Patrick Feeley is offline
post #4 of 8 Old 05-22-2013, 01:50 PM Thread Starter
Express.1's Avatar
thanks I try to measure the pressure and then tell you ......
post #5 of 8 Old 05-27-2013, 12:55 PM Thread Starter
Express.1's Avatar
hello, I have a doubt with a battery that could be unhealthy to turn off the engine after 5 minutes? also what sets the fuse 22? thanks
post #6 of 8 Old 05-27-2013, 06:25 PM
Quoted: 13 Post(s)
If you have one bad battery, that could cause problems with starting. Many times if one battery is bad, the Check Engine Light will be flashing rapidly along with rapid clicking of the IDM relay in the underhood fusebox. If fuse #22 is blown, the fuel heater (driver's side of the fuel filter bowl, second wiring connection down from the top) has probably shorted (disconnect it and replace the fuse). If the Wait-to-Start light is not illuminating, that may be your problem. Cheers!
post #7 of 8 Old 05-28-2013, 09:44 AM Thread Starter
Express.1's Avatar
changed batteries and motor party .... 5 minutes and stop engine again ..... could be the air filter that fishing? near the pump or filter? Shrader valve controls what? thanks for the help
post #8 of 8 Old 05-28-2013, 09:51 AM Thread Starter
Express.1's Avatar
or better ...... into the bowl of the filter there is some sensor that could turn off engine after 5 minutes? it does not start right away but you have to wait a little time to share helots king. I'm sorry but I have a ford mechanic's impractical .... thanks
