cps has went bad bad??? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 05-19-2013, 05:10 AM Thread Starter
ole96stroker's Avatar
So i was coming down the interstate last night and my truck just shut off and wouldnt start back, im getting fuel and the rpm's will go up when you crank it. It has been acting funny here lately about idling and no check engine.light, is this mpre then likely my cps ???thanks
******1996 ford f250 powerstroke 5 spd 4x4******
***170,000 miles, ts 6 pos, intake, exhuast***
ole96stroker is offline
post #2 of 7 Old 05-19-2013, 08:28 AM
Patrick Feeley's Avatar
Quoted: 15 Post(s)
You might change it just to see (they are cheap enough these days to do that). If it doesn't work you have a spare for the glovebox (always a good idea). Cheers!
Patrick Feeley is offline
post #3 of 7 Old 05-19-2013, 12:03 PM Thread Starter
well stil no start just put one on. any ideas what else could be it??? thanks
post #4 of 7 Old 05-19-2013, 12:43 PM Thread Starter
Could it be my icp? is say's if covered in oil inside it will go bad and mine is where the pigtail goes in.thanks
post #5 of 7 Old 05-19-2013, 06:07 PM
Quoted: 15 Post(s)
It could be the ICP (but hate to keep throwing parts at it). Will it start with the ICP unplugged? How's the wiring to the IPR look? Cheers!
post #6 of 7 Old 05-19-2013, 07:06 PM Thread Starter
I believe I found out what it is, I took my fuel bowl apart to where I could see the ipr and the nut has some how came off the end of it the one that goes against the bushing, the part that you plug the pigtail to was just moving freely, gonna go get a nut and hope this fix's her.
post #7 of 7 Old 05-20-2013, 11:57 AM
Quoted: 15 Post(s)
It should fix it. If the solenoid is moving around the IPR may or may not work correctly. Cheers!
