Fuel Leak- HELP - Ford Powerstroke Diesel Forum
post #1 of 4 Old 05-15-2013, 05:35 PM Thread Starter
Fuel Leak- HELP
Hello, I bought a 1995 7.3 on Saturday and it has a slow fuel leak. Appears to be coming from the back side of the block and running down into the transmission bell housing. Any common things to check, ideas, or help in general would be very appreciated. I would like to diagnose the problem and maybe fix it tomorrow. I just need some advice on where to start. Thanks in advance for the help.
Lutz'96 is offline
post #2 of 4 Old 05-17-2013, 03:03 PM
r_jacksondiesel's Avatar
Location: Sunshine Coast or Baja California...Depends on the temperatiure
If it's dripping around the bell housing it is most likely coming out of the back of the valley on top of the engine. Take of the plastic cover, get a flashlight and a mirror and start hunting around the fuel filter housing and lift pump with the engine running.
r_jacksondiesel is offline
post #3 of 4 Old 05-18-2013, 03:20 PM
Patrick Feeley's Avatar
Quoted: 13 Post(s)
Yes, lots of places to leak on top of the engine! When enough fuel gets in the valley, it will drain down the passenger side rear of the engine. If the valley is dry, look at the back of the heads where the supply lines go into the heads. There are rubber seals there that can be replaced (kind of a pain in some cases to replace). Cheers!
Patrick Feeley is offline
post #4 of 4 Old 05-18-2013, 03:24 PM
nohsp4u's Avatar
Pay close attention to the blue fuel hoses. The po of my rig changes the pump and fuel filter but left the old hoses, they are cracking and leading very slight.
1997 F-350 XLT Lariat Crewcab long box 4x4. Oxford white with an ugly green. 133xxx miles. Hide away goose neck, banks turbo, exhaust, inner cooler, intake filter and gauges.
nohsp4u is offline
