Missing bad through out entire rpm range - Ford Powerstroke Diesel Forum
post #1 of 3 Old 05-13-2013, 02:12 PM Thread Starter
95f350powerstroke*'s Avatar
Hey guys the other day I was sitting in traffic and my truck acted like it was missing real bad and just ran terrible. I drove it to my destination. Oh and no codes were thrown. I shut it off and after about a half hour I started it up and it has ran fine since. Any ideas? Injectors? Oh it's a 95 with 110k
1995 F-350 Reg. 4x4 7.3, TDP chip with TW tunes, gauges, DIY intake 5" turbo back
95f350powerstroke* is offline
post #2 of 3 Old 05-14-2013, 07:12 PM Thread Starter
Bump
post #3 of 3 Old 05-15-2013, 03:28 AM
Patrick Feeley's Avatar
Quoted: 15 Post(s)
I would begin with an inspection of the four valvecover harness connections. Also do a "sniff test" on the oil filler cap to see if it smells like burned electrical insulation. Check the nut on the back side of the IPR to make sure it is snug and check the IPR wiring too. Cheers!
Patrick Feeley is offline
