Long starts ... where to begin? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 05-08-2013, 01:57 PM Thread Starter
Let me preface by admitting that I am a bit of a greenhorn when it comes to working on diesels (by "a bit", I mean almost completely ).
Last year I got a new-to-me '94.5 7.3L F350 4x4 (manual everything).
Before buying it, the guy said that, other than long-cranking starts, it ran great (a "less than $5 fix").
His understanding what that there were some degraded rubber washers in the fuel pump assy that were letting the fuel lines drain back into the tank .
I gave him a week to fix it, then went to check it out.
When I got the truck, it started reliably and reasonably quickly.
A few weeks after buying it, I hooked up the 5th wheel for a little vaca.
The clutch was in less-than-new condition, but adequately functional, and we arrived without so much as a hiccup. I was very pleased.
Then ... I had to maneuver up a (fairly steep) hill in reverse to get into our spot (my first time ever reversing a big/heavy trailer up a real hill with a manual transmission) ... and quickly proceeded to completely toast the clutch
Well, after being out of commission for several months, the truck is up and driving again. We put a complete clutch kit in ... bearings, SMFW, etc.
Everything seems to be running and shifting wonderfully, but now I've gotta floor it and let it crank for a kinda long time to start it.
Is it likely that the "rubber washer" issue is back, or??
What, in your collective experience, would be your first (few) suspect(s)?
mOrloff is offline
post #2 of 4 Old 05-08-2013, 03:46 PM
Do a quick search for starting problems. Most of them will start by telling you to check the glow plug system (relay and individual plugs), then move on to the fuel system/filter condition.
Haulstroker is offline
post #3 of 4 Old 05-08-2013, 03:47 PM
jesilvas's Avatar
Quoted: 2 Post(s)
I doubt it would be a GP issue unless it ONLY happens when cold.
You need to test fuel pressure.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #4 of 4 Old 05-09-2013, 02:34 PM Thread Starter
Thanks guys.
I'll start with the fuel pressure/filters.
mOrloff is offline
