Brake light and P1111 code - Ford Powerstroke Diesel Forum
post #1 of 12 Old 05-08-2013, 08:27 AM Thread Starter
nohsp4u's Avatar
Ok, i have a Genisys EVO but,. that does not mean i know how to use it. While driving, i noticed my dash brake light goes on. Odd, it seems to float at a stop, i.e. not a solid stop.
Ran tests and i get to the screen where you can watch the parking brake light go on and off, when i apply brake, light goes on, when i release it does not always go off. When it is off i rev the engine and apply the brake, light goes on. Any help. I suspect the brake pedal and or e-brake switch but could it be the RABS? I do not have the ABS cable with me, so i can test this weekend.
Also, while running various tests, the buzz test is good, running other DTC scans, i get the P1111 UVC harness. Truck seems to run fine, i plan to disconnect the sensor and use electrical parts cleaner to clean the connector and then some dielectric grease to prevent issues later. Am i wasting my time? What other symptoms should i be getting if the UVC harness is truly bad?
Thank You.
1997 F-350 XLT Lariat Crewcab long box 4x4. Oxford white with an ugly green. 133xxx miles. Hide away goose neck, banks turbo, exhaust, inner cooler, intake filter and gauges.
nohsp4u is offline
post #2 of 12 Old 05-08-2013, 10:36 AM Thread Starter
nohsp4u's Avatar
Anyone able to give me a clue? i am not opposed to begging! LOL
nohsp4u is offline
post #3 of 12 Old 05-08-2013, 12:54 PM
Patrick Feeley's Avatar
Quoted: 9 Post(s)
Is the ABS light on? If it is only the Brake light, check the fluid lever in the reservoir and if that's good, you may have the vacuum pump heading south (which is what I would suspect). The P1111 code is the "System Pass" code (not a UVCH code). If the UVCH was truly bad, you would have a miss from one or two injectors not functioning or even the whole bank shutting down. Your UVCH is probably OK if it passed the buzz test and the engine runs good. By-the-way, I don't find the green ugly
Cheers!
Patrick Feeley is offline
post #4 of 12 Old 05-08-2013, 01:18 PM Thread Starter
nohsp4u's Avatar
Cheers!
LOL, no, the green is growing in me.
I will check the items you suggested, and as for the P1111, i guess that is why the EVO says System pass. LOL it just came to me it read that after reading your post.
If the vac pump goes while i am driving, do you suspect i will not stop, or have a hard time? i ask because i am 200 miles from home for the next two three days. I got a heavy duty bumper but it is no good when you hit a smart car. LOL
nohsp4u is offline
post #5 of 12 Old 05-08-2013, 07:51 PM Thread Starter
nohsp4u's Avatar
Cheers!
Patrick, Do you know what vacuum i should have if i were to test the vacuum pump with a gauge? I have an EVO but not sure if it tests that or not. Will run it in the AM. I plan to buy a vac gauge tomorrow and work on this at work. I am currently over 100 miles from home where all my tools and equipment are and ford is booked. Really not looking forward to crossing the SF bay bridge with no power brakes again. LOL
nohsp4u is offline
post #6 of 12 Old 05-08-2013, 08:20 PM
Quoted: 9 Post(s)
It's 17-21 in-Hg when running at normal operating temperature. Cheers!
post #7 of 12 Old 05-08-2013, 08:48 PM Thread Starter
nohsp4u's Avatar
I will buy the gauge and test in the morning but, i found something interesting, maybe you or someone else could tell me if it is something.
With the Genisys Evo running custom datastream and set to focus on the following
1) Brake Pedal Position
2) Brake pedal Press Applied sw
3) Park brake apply sw
I am sitting at idle, gear in park engine warm. Here is the action and the response
1) apply brake pedal, changes from on to off etc, seems to function
2) stays in off position no matter what i do. press the brake, set e-brake, no affect
3) this stays on no matter weather the e-brake is applied or not.
I removed the e-brake switch, seems very simple. I am no electrician but, it appears this ground to body, when the brake is applied the ground is broke and a light goes on. My light stays on. I put an ohm meter across the ground plate and the connector, meter starts at 0.2 with leads crossed, reads same when i touch the ground plate and the connector. when i engage the switch meter goes to OL. seems to me the switch is working. Can anyone tell me, first, why my park brake apply sw stays on, and two would this cause the hard pedal press and little brake power?
Per the Factory test procedure, the parking brake applied is one issue, so iif my switch is lying to the computer, maybe i found a cheap fix, if only the switch were bad.
Please help!
nohsp4u is offline
post #8 of 12 Old 05-09-2013, 11:44 AM
Quoted: 9 Post(s)
If I recall correctly, when the parking brake is applied the switch should close and provide the path to ground (and illuminating the light). I had my $12 AIC ground circuit wired into the wiring for the switch so that it only worked with the parking brake applied. The switch should have nothing to do with the hard pedal and little brake power (that's usually the vacuum pump). Cheers!
post #9 of 12 Old 05-09-2013, 12:25 PM Thread Starter
nohsp4u's Avatar
Patrick, please answer this for me. There is a vac hose coming from the pimp going to the low vac switch. Do i disconnect it there and connect a vac gauge to test? According to the factory manual test sheet, there is a low vac switch, how would I test that? Tnanks for your help, 2 hours until I have to drive home, ugh. Lol
nohsp4u is offline
post #10 of 12 Old 05-10-2013, 11:58 AM
Quoted: 9 Post(s)
Probably saw this too late for you, but I would say connect the gauge to any connection you can disconnect on the vacuum manifold or near the pump. As far as testing the switch, I'll have to look when I get home (where the manuals are). Cheers!
