Can you help me identify this leak (picture added) - Ford Powerstroke Diesel Forum
post #1 of 3 Old 05-06-2013, 11:54 AM Thread Starter
Howdy,
Fuel leaks seem common. Got a drip every 4 to 5 seconds from this brass fitting. The one where the wire comes in. I believe its running back down the valley and all the way to the ground at the rear of the oil pan. At least I hope that it is the same leak!
Can you help me with identification and possibly what needs to be done?
Thanks.
perspective is looking from passenger quarter panel.
countryroad is offline
post #2 of 3 Old 05-06-2013, 12:02 PM
Patrick Feeley's Avatar
Quoted: 17 Post(s)
I can't see the picture (I think the IT folks block it here), but I'll guess it may be the fuel restriction sensor (they love to leak). If thta's what it is, you can replace it with a 1/8 NPT plug. Do not overtighten it as you can crack the housing! The restriction sensor isn't really needed if you are good about replacing filters. The sensor doesn't seem to be able to handle the pulsing caused by the mechanical fuel pump. Cheers!
Patrick Feeley is offline
post #3 of 3 Old 05-06-2013, 01:17 PM Thread Starter
Your good man! Without a picture...
Looked it up that indeed the part. Thanks for explaining the torque warning too.
