Fuel regulator leaking - Ford Powerstroke Diesel Forum
post #1 of 6 Old 05-05-2013, 07:14 PM Thread Starter
r_jacksondiesel's Avatar
Location: Sunshine Coast or Baja California...Depends on the temperatiure
I have a leak at the bottom of the fuel pressure regulator. The leak is coming from the brass fitting at the bottom that is held in with a snap ring. There was a thin black o-ring in there. I found a Cat o-ring at work that was close, but it's still leaking. Ford dealer here can't help me. Anyone have any info on a part number or a kit to fix this?
r_jacksondiesel is offline
post #2 of 6 Old 05-05-2013, 07:55 PM
Patrick Feeley's Avatar
Quoted: 15 Post(s)
Dieselorings.com sells a repair kit for it with the mesh screen: Fuel Bowl Regulator Filter Repair Kit
It also looks like you could get the o-ring in this regulator repair kit a bit cheaper: Fuel Regulator Repair Kit
Or you could do the complete fuel bowl reseal even cheaper: Complete Fuel Bowl Reseal Kit for the 1994.5 - 1997 Ford 7.3L Diesel
Cheers!
Patrick Feeley is offline
post #3 of 6 Old 05-05-2013, 08:05 PM Thread Starter
That's so weird, the more you get the cheaper it is! I see a Ford number (Ford 2C3Z 9157 AA) that I might give to the parts guy and see what happens. Thanks.
post #4 of 6 Old 05-06-2013, 11:58 AM
Quoted: 15 Post(s)
The first one has the mesh screen which lists at Fors for $88 (Ouch! ... Tousley has it for about $46).
The second one has the orifice vent screen in it, so that adds to the cost too. Cheers!
post #5 of 6 Old 05-17-2013, 03:10 PM Thread Starter
I got the Kit from Ford. It came with a few other o-rings and a new screen, so I changed all the and now the leak is gone.
post #6 of 6 Old 05-18-2013, 03:21 PM
Quoted: 15 Post(s)
Nice work! Cheers!
